Nejc
Rep Power: 11 ![]() |
Hello!
How do I set up an ACMI patches for a pump? I have an impeller that's always touching the volute boundary, but volute is not always touching the impeller. The incompressible/pimpleDyMFoam/oscillatingInlet2D tutorial case is very complicated and I can't tell what's what in there. But I can't just 'copy' it because in my case impeller has no 'nonOverlappingPatch'. Or does it? Do I need to run createBaffles? Thanks! |
Nejc
Maybe I should ask this question first: is it even necessary to use ACMI or should AMI suffice? The thing is that I'm starting to believe the way I split the mesh for AMI is ruining my results. Here's my impeller that includes a 'rim' of fluid that actually belongs to volute:
https://www.cfd-online.com/Forums/at...h-impeller.jpg Am I right? |
Brian Willis
Rep Power: 16 ![]() |
You should use an AMI boundary for a system like yours. Have a look a this tutorial which sets up the case for a rotor using AMI boundaries.
Moving Rotor (AMI) (Holzmann CFD) |
Nejc
according to the tutorial, my case is set up exactly the same.
my theory was that the ring that is 'attached' to impeller (but is not rotating in reality, see the attached image) messes up the results. if that works for mr. Holzmann, i guess it should work for me too ![]() thanks! |
Brian Willis
I would assume those forces would have to be added in the MRF case since it is not actually a moving/dynamic mesh, but rather a moving reference frame, though I have only been working with AMI patches for my work. Good luck!
Tobias Holzmann
Rep Power: 52 ![]() ![]() ![]() |
Hi all,
first thanks for mentioning my tutorial. I appreciate this and I am happy that it will help the community. I just want to mention a few things related to my case and other cases using ACMI and MRF.
Keep foaming, Tobias Holzmann |
Nejc
so my guess is the closest-to-actual model would be AMI on inlet and ACMI on the outlet.
i can't set up ACMI because in all tutorials there are four combinations of patches:
but in my case, moving part (impeller) is never blocked so i have no idea where to start. i hate it when tutorials use some crazy shit voodoo to set up something very simple and never explain anything. ![]() |
Tobias Holzmann
you should provide both blockage and coupled patches. Both are just some duplications. Actually, you should have both of them. If for any reason you will never have any blocking on one patch, who cares? Imaging the oscillating tutorial and reduce the oscillation. Then you would probably only have a blockage on one side while the other one is always coupled. Could you provide a picture/draft of your geometric problem? By the way. What you explain fits 100% to my other case ![]() Simple ACMI (Holzmann CFD)
Keep foaming, Tobias Holzmann Last edited by Tobi; June 24, 2020 at 12:08. |
#9 |
Nejc
if that is so, let me check your tutorial first. i'll bother you later if i can't get it working
![]() thanks! |
Display Modes | |
Case Setup seems slow | russh | ANSYS | 0 | January 30, 2017 06:43 |
How to Initialise my LES case using my RANS case is there any utility for it ? | Alhasan | OpenFOAM Running, Solving & CFD | 2 | May 10, 2014 00:14 |
Can't run a case in HelyxOS with an imported mesh from Fluent | HHOS | OpenFOAM Running, Solving & CFD | 0 | July 2, 2013 06:25 |
OpenFOAM case setup and work flow - what are you using? | Arnoldinho | OpenFOAM Pre-Processing | 4 | July 18, 2010 09:16 |
Parallel case setup boundry conditions snappyhexmesh | oskar | OpenFOAM Pre-Processing | 5 | September 11, 2009 01:12 |
