JonathanG |
July 19, 2017 11:18 |
Parallel Processing Problem
Hi all,
I hope I get my terminology right!
I am running a case on a cluster mp2/mammoth and before submitting the case, I did a little test by typing rhoPimpleFoam, and everything ran smoothly.
I then submitted the case to run on the cluster and I get an error right away:
[33]
[33]
[33] --> FOAM FATAL ERROR:
[33]
request for volScalarField psi from objectRegistry region0 failed
available objects of type volScalarField are
19
thermo:mu
thermo:psi
nut
K
K_0
rho
(1|A(U))
dpdt
delta
momentumSource:rA
thermo:psi_0
e_0
alphat
rho_0
p
T
e
s
thermo:alpha
[33]
[33]
[39]
[39]
[39] --> FOAM FATAL ERROR:
[39]
19
thermo:mu
thermo:psi
nut
K
K_0
rho
(1|A(U))
dpdt
delta
momentumSource:rA
thermo:psi_0
e_0
alphat
rho_0
p
T
e
s
thermo:alpha
[39]
[39]
[39] From function const Type& Foam::objectRegistry::lookupObject(const Foam::word&) const [with Type = Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh>]
[39] in file /cvmfs/opt.usherbrooke.ca/CentOS6/OpenFOAM/OpenFOAM-4.0/src/OpenFOAM/lnInclude/objectRegistryTemplates.C at line 193.
[39]
FOAM parallel run aborting
[39]
[33] [54] [69]
[69]
[69] --> FOAM FATAL ERROR:
[69]
19
thermo:mu
thermo:psi
nut
K
K_0
rho
(1|A(U))
dpdt
delta
momentumSource:rA
thermo:psi_0
e_0
alphat
rho_0
p
T
e
s
thermo:alpha
[69]
[69]
[69] From function const Type& Foam::objectRegistry::lookupObject(const Foam::word&) const [with Type = Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh>]
[69] in file /cvmfs/opt.usherbrooke.ca/CentOS6/OpenFOAM/OpenFOAM-4.0/src/OpenFOAM/lnInclude/objectRegistryTemplates.C at line 193.
[69]
[69]
From function
[54]
[33] [54] in file --> FOAM FATAL ERROR: /cvmfs/opt.usherbrooke.ca/CentOS6/OpenFOAM/OpenFOAM-4.0/src/OpenFOAM/lnInclude/objectRegistryTemplates.C at line
[54] 193.
19
thermo:mu
thermo:psi
nut
K
K_0
rho
(1|A(U))
dpdt
delta
momentumSource:rA
thermo:psi_0
e_0
alphat
rho_0
p
T
e
s
thermo:alpha
[54] [33]
I contacted the help center at the cluster but they said they think it's an input file problem. This is confusing since it's working when I type rhoPimpleFoam - it ran for over 8 hours without a problem, but I need to run it on the cluster otherwise it'll take wayyyy too long.
Any help is much appreciated!
Thanks in advance,
Jonathan
