setFields problems
Dear Foamers,
I am quite new to CFD simulations, specially OpenFoam, and I am trying to start with simple simulation. I have an open channel with constriction in some parts, which fluid flows through it and I want to use interFoam solver in order to investigate flow field and the effect of these constrictions on water level surface. I know the velocity at the inlet and flow depth at the outlet. My main question is about alpha.water and setFeildsDict files. 1) what should I write for inlet in alpha.water file? 2) And I don’t know which box should I introduced in setFieldsDict file? Should I introduced a box which cover whole the channel? For example, I have a flume with 6m length and 1m width which flow depth is 0.3m. Should I write setFeildsDict as below? defaultFieldValues ( volScalarFieldValue alpha.water 0 ); regions ( boxToCell { box (0 0 0) (6 1 0.3); fieldValues ( volScalarFieldValue alpha.water 1 ); } ); Or I should only introduce a small box at the inlet and let this box flows through the channel? I mean: defaultFieldValues ( volScalarFieldValue alpha.water 0 ); regions ( boxToCell { box (0 0 0) (0.5 1 0.3); fieldValues ( volScalarFieldValue alpha.water 1 ); } ); So sorry for my very basic questions. Best Regards Neshat |
Hi
both methods are possible :) and true, just continue simulation and see which one fit your purpose. |
Thanks a lottt.
For the first question, I used zeroGradient for inlet, which seems OK. |
you can use both zeroGradient and inletOutlet boundary condition. For your second question, I agree with Nima. good luck!! |
