Remove the Turbulence Model
Old   September 22, 2017, 11:16
Default Remove the Turbulence Model
Jem
Jem01 is on a distinguished road
Hey, how can i remove the turbulence model?
Im using the Channel395 and i want to remove the turbulence model. Is it enough to change the Turbulence model from "WALE" to "laminar" in the turbulence Properties?
I did that, but i kinda get the same results.
Greetings
Jem01
Jem01 is offline   Reply With Quote
Old   September 25, 2017, 09:27
BlnPhoenix is on a distinguished road
Greetings
Jem01
Yes, setting to "laminar" is enough to run without turbulence modelling. What kind of results are you expecting?
BlnPhoenix is offline   Reply With Quote
Old   September 25, 2017, 09:37
Jem
Im trying to reconstruct the famous dns channel flow from Kim, Moin, Moser with OpenFOAM.
I Attached my results. S2 is with turbulence model and S3 is without. I Hoped i get closer to the KMM reference by removing the turbulence model, but it dosnt. I also changed the Grid Resolution and the time resolution d^*.
My aime is to get as close to the reference as possible.
Old   September 25, 2017, 09:41
Jem
Here proper Attachments
Old   September 25, 2017, 09:45
What is your mesh resolution?
Old   September 25, 2017, 11:24
Jem
S1 Resolution = 60 000 (with turbulence Model, d* = 0m3)
S2 Resolution changed from 60 000 to 260 000
S3 Turbulence Model removed
S4 d* from 0,3 changed to 0,03
Old   September 26, 2017, 02:38
Hi, i'm not familiar with the KMM DNS case but a quick google search showed me they used a mesh in the Order of ~3 Mio. cells. So if you want to get there without turbulence modelling (=DNS) there is no alternative to increasing mesh size further, i suppose.
The real question seems why your LES solution is off from reference case. I'm no expert in LES unfortunately but i know that BC's is an important topic. Basically LES solutions are very sensitive to the right inlet/outlet conditions. I would also check the WALE model regarding mesh sizing etc.
Good luck.
Question about matching of solver and turbulence model louistse OpenFOAM Running, Solving & CFD 1 February 1, 2017 21:36
Error in Two phase (condensation) modeling adilsyyed CFX 15 June 24, 2015 19:42
Overflow Error in Multiphase Modelling with Two Continuous Fluids ashtonJ CFX 6 August 11, 2014 14:32
An error has occurred in cfx5solve: volo87 CFX 5 June 14, 2013 17:44
Wrong calculation of nut in the kOmegaSST turbulence model FelixL OpenFOAM Bugs 27 March 27, 2012 09:02
