checkMesh fails after introduction of a cyclicAMI
3 Attachment(s)
Hello everyone,
I'm relatively new to OpenFoam and new to this Forum which means that i still has a lot to learn from you all, so thank you in advance ! For my case i'm using OpenFoam 4.1. I first load a fluent mesh which is rather a complex one with several interfaces and bodies (the same mesh works perfectly in CFX). I use fluent3DMeshtoFoam to convert the mesh and it goes well and the boundary file is created with all the patches and walls i already had previously in CFX. At this point, running the checkMesh was no problem at all and the log out of it is (first_checkMesh). When i try to modify the boundary file to change the types of some patches to cyclicAMI i get the error attached as (second_checkMesh). Same error if i launch rhoSimpleFoam. May be important to mention that originally all the boundries in the file boundary are only patch or wall. I looked into some threads and the error seems to occur because the the number of patches in boundary does not match with the declared number of patches which i checked and is not the case. I also attach my modified boundary file. Your help is much appreciated ! |
The errors you face are dummy errors...you deleted some }) in some definition of patches...
In any case with first output, if I were you, i should consider to remesh, especially for the 22614(!!!) faces with higher non-orthogonality (>80). Further more even with few skewfaces and high aspect ratio cell, you can have problems... Regards |
Thanks for the reply.
I'am aware of the non-orthogonality problems im my mesh which will be one of the next steps to deal with. I'm sorry but i still don't see where i missed the some of } or ). could someone point that out ? Thank you in advance |
indeed the error message could lead to misunderstanding, but reading carefully, it tell us that an Code:
or EOF e.g. Code:
neighbourPatch OUTLET_SPIRALE_TO_OUTLET_BOX-SIDE-2; |
Thank you very much, it was indeed a dummy error.
regards |
