open channel in pipmleFOAM (using LES)
Like Tree1Likes
  • 1 Post By hulli
Old   November 24, 2017, 09:05
Default open channel in pipmleFOAM (using LES)
maliheh
maliheh is on a distinguished road
Hi everybody,
I try to model an open channel with smooth bed in OpenFOAM software by pimpleFOAM (LES) solver. I will be appreciated if you help me to model it properly. Actually, I modeled an open channel. Unfortunately, I think my model has some problems. The specifications of my model as follow:
long 2.5 m; width= height =0.2 m (channel)
mean velocity =0.21 m/s; water height= 0.045 m; size mesh 2*2*2 mm
B.C
(0/U)
atmosphere
        type            symmetry;
    walls
        type            fixedValue;
        value           uniform (0 0 0);
   outlet
        type            inletOutlet;
        inletValue      uniform (0 0 0);
        value           uniform (0.21 0 0);
    inlet
         type            fixedValue;
    smooth
        type            fixedValue;
(0/P)
boundaryField
atmosphere
        type            symmetry;
    walls
        type            fixedFluxPressure;
        value           uniform 0;
   inlet
          type           zeroGradient;
    outlet
           type           zeroGradient;
smooth
        value           uniform 0;
(0/K)
     atmosphere
        type            symmetry;
    inlet
        type            fixedValue;
        value           uniform 0.000165;
    outlet
         type            inletOutlet;
        inletValue       uniform 0.000165;
    walls
        type            fixedValue;
        value           uniform 0;
  smooth
         type            fixedValue;
         value           uniform 0;
controlDict
application     pimpleFoam;
startFrom      latestTime;
startTime       0;
stopAt          endTime;
endTime 600;
deltaT          0.001;
writeControl    timeStep;
writeInterval   200;
purgeWrite      0;
writeFormat     ascii;
writePrecision  6;
writeCompression off;
timeFormat      general;
timePrecision   6;
//runTimeModifiable   true;
adjustTimeStep    yes;
maxCo    0.5;
functions
    fieldAverage1
        type            fieldAverage;
        functionObjectLibs ( "libfieldFunctionObjects.so" );
        enabled         true;
        outputControl   outputTime;
        fields
            U
                mean        on;
                prime2Mean  on;
                base        time;
            p
                mean        on;
                prime2Mean  on;
                base        time;
((fvSchemes))
ddtSchemes
    default           Euler;
gradSchemes
    default         Gauss linear;
divSchemes
    default         none;
    div(phi,U)      Gauss linear;
    div(phi,k)      Gauss limitedLinear 1;
    div(phi,B)      Gauss limitedLinear 1;
    div(B)          Gauss linear;
    div(phi,nuTilda) Gauss limitedLinear 1;
    div((nuEff*dev(T(grad(U))))) Gauss linear;
laplacianSchemes
    default         Gauss linear corrected;
interpolationSchemes
    default         linear;
snGradSchemes
    default         corrected;
fluxRequired
    default         no;
    p               ;
fvSolution
solvers
    p
        solver          GAMG;
        tolerance       0;
        relTol          0.1;
        smoother        GaussSeidel;
        nPreSweeps      0;
        nPostSweeps     2;
        cacheAgglomeration true;
        nCellsInCoarsestLevel 10;
        agglomerator    faceAreaPair;
        mergeLevels     1;
    pFinal
        $p;
        smoother        DICGaussSeidel;
        tolerance       1e-06;
        relTol          0;
    "(U|k)"
        solver          smoothSolver;
        smoother        symGaussSeidel;
        tolerance       1e-05;
        relTol          0.1;
    "(U|k)Final"
        $U;
        tolerance       1e-05;
        relTol          0;
PIMPLE
    nOuterCorrectors 1;
    nCorrectors     2;
    nNonOrthogonalCorrectors 0;
    pRefCell        1001;
    pRefValue       0;
1. I entered initial velocity of flow equal with 0.21 m/s (as mean velocity) but mean velocity is increasing during the channel while you may know it should be constant. Would you help me to solve this problem?
2. I want to verify my model with results from a paper that the plotted figure is attached. Based on this figure my model is not in good agreement with results from paper. (I didn't consider air influence on my model. Do this difference between my model and paper is related to the air effect???-paper didn't mentioned about air effect-)
Thank you for your valuable time.
Tobi: Put all your content of the files into code tags! Please keep clearance!
maliheh is offline   Reply With Quote
Old   November 24, 2017, 13:17
hulli graemer
hulli is on a distinguished road
from my little experience with the channel tutorial and looking at your profile I think you need to run that a bit longer so the profile will equilibrate ... I meant that you should try cyclic boundaries and let it run for a very long time until you will see turbulences... Then do a timeaverage and your profile should HOPEFULLY fit ... may be that helps ... Best H
QL-dut likes this.
hulli is offline   Reply With Quote
Old   November 25, 2017, 05:46
maliheh
Many thanks for your response.
Actually, the channel has been run about 600 sec. Does this run time is enough???
Do my file(0) and system file are correct? If it is possible for you, please check my files.
I appreciate you.
Old   November 25, 2017, 12:20
hulli graemer
Well I guess looking at the Profiles that you want to get a fully turbulent flow? Right ? As I mentioned I never did any two Phase flows with OF. But in oder to get turbulences and a locartitmic shaped profile as shown in your figure and done in the tutorial channel 3xx you have either to run the case for a very long time... or you Speed that up using the utilities boxturb or perturbU to generate some white noise that helps to get a fully turbulent flow. The development of turbulences is also denpendent on your resolution (check your Yplus) and the Dimensions of your domain. After the turbulences developed do that timeaveraging I mentioned above... Just check the forum in that issue there are million of posts on that... i hope that helps
Enabling Open Channel Flow Sub-Model in Mixture model cod213 FLUENT 0 January 10, 2017 13:40
Open Channel Boundary Conditions Issues Env FLUENT 8 June 28, 2016 16:05
[swak4Foam] swak4foam building problem GGerber OpenFOAM Community Contributions 54 April 24, 2015 16:02
[swak4Foam] Swak4FOAM 0.2.3 / OF2.2.x installation error FerdiFuchs OpenFOAM Community Contributions 27 April 16, 2014 15:14
interFoam & decomposition method: scotch MacGyver OpenFOAM Running, Solving & CFD 2 May 23, 2012 07:00
