StitchMesh crashes on circular patch with singularity |
January 16, 2018, 10:14 |
Rep Power: 10 |
Dear FOAMers,
I've been searching the forum and the web now for hours but did not find a solution to my problem. Hopefully you can help me: I need to stitch two planar, perfectly aligned patches (<auto5> and <auto14>). By 'perfectly', I mean 'perfectly'. They share identical coordinates at all of their nodes (see images). For no obvious or understandable reason, stitchMesh always crashes when I try to stitch the patches, throwing the following message: Code:
/*---------------------------------------------------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 4.1 | | \\ / A nd | Web: www.OpenFOAM.org | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ Build : 4.1 Exec : stitchMesh -overwrite auto5 auto14 Date : Jan 16 2018 Time : 15:51:51 Host : "thinkpadYoga" PID : 3267 Case : /home/lichtmes/Desktop/bloomyboxxExamples/MegaCadsMesh/mesh nProcs : 1 sigFpe : Enabling floating point exception trapping (FOAM_SIGFPE). fileModificationChecking : Monitoring run-time modified files using timeStampMaster allowSystemOperations : Allowing user-supplied system call operations // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // Create time Create mesh for time = 0 Coupling patches auto5 and auto14 Resulting (internal) faces will be in faceZone auto5auto14CutFaceZone Note: the overall area covered by both patches should be identical ("integral" interface). If this is not the case use the -partial option Adding pointZone auto5auto14CutPointZone at index 0 Adding faceZone auto5auto14MasterZone at index 0 Adding faceZone auto5auto14SlaveZone at index 1 Adding faceZone auto5auto14CutFaceZone at index 2 Sliding interface parameters: pointMergeTol : 0.05 edgeMergeTol : 0.01 nFacesPerSlaveEdge : 5 edgeFaceEscapeLimit : 10 integralAdjTol : 0.05 edgeMasterCatchFraction : 0.4 edgeCoPlanarTol : 0.8 edgeEndCutoffTol : 0.0001 Reading all current volfields #0 Foam::error::printStack(Foam::Ostream&) at ??:? #1 Foam::sigFpe::sigHandler(int) at ??:? #2 ? in "/lib/x86_64-linux-gnu/libc.so.6" #3 Foam::slidingInterface::projectPoints() const at ??:? #4 Foam::slidingInterface::changeTopology() const at ??:? #5 Foam::polyTopoChanger::changeTopology() const at ??:? #6 Foam::polyTopoChanger::changeMesh(bool, bool, bool, bool) at ??:? #7 ? at ??:? #8 __libc_start_main in "/lib/x86_64-linux-gnu/libc.so.6" #9 ? at ??:? Floating point exception (core dumped) I'm pretty sure, there is no easy way to workaround stitchMesh's inability to perform as intended. Any help or suggestions would be appreciated, anyway. Kind regards and thanks in advance, Martin Last edited by NablaDyn; January 16, 2018 at 10:15. Reason: Typo |
March 5, 2019, 06:01 |
Rep Power: 10 |
After a deeper review of the issue, I found out that the problem was due to degenerate edges in the faces. This means, The triangles around the singularity were defined as quads with each of them having two coincident nodes. Maybe the info is helpful to others.
I corrected the faces and stitchMesh now operates as wished. |
November 2, 2020, 08:59 |
giovanni
Rep Power: 8 |
Hi NablaDyn , I have the same issue.. could you explain in a more detailed way how you solved the problem? thanks
November 2, 2020, 10:51 |
#4 | |
Mark Olesen
Rep Power: 40 |
You should definitely mention which version of stitchMesh you are using. Some changes went into OpenFOAM-v1712 to support a dictionary-driven version, but also fixed a few addressing bugs. Not sure if you would still have issues with OpenFOAM-v1912, v2006 etc, but would be good to know. |
November 2, 2020, 15:32 |
#5 | |
Rep Power: 10 |
In my case, the problem was related to how the individual faces of the patch were compiled by a custom software I wrote. The patch you see in the images has a singularity at its centre, whereby those faces connected to the singularity need to be triangular instead of quadrilateral. But, in an older version, my software was coded to compile any tri face as a degenerate quad, however with two collapsed vertices - simply out of 'coding convenience'. Thus, also any tri in my mesh consisted of four nodes and stitchMesh could not handle it. After fixing my software such that degenerate quads are now described - more consistently - as tris, stitchMesh behaves as expected. |
y+ and u+ values with low-Re RANS turbulence models: utility + testcase | florian_krause | OpenFOAM | 114 | August 23, 2023 05:37 |
[Commercial meshers] Mesh conversion problem (fluent3DMeshToFoam) | Aadhavan | OpenFOAM Meshing & Mesh Conversion | 2 | March 8, 2018 01:47 |
Possible bug with stitchMesh and cyclics in OpenFoam | Jack001 | OpenFOAM Pre-Processing | 0 | May 21, 2016 08:00 |
[Other] How to create an MRF zone ? | aminem | OpenFOAM Meshing & Mesh Conversion | 2 | December 8, 2014 10:45 |
[mesh manipulation] stitchMesh problems along patch edges | ribe | OpenFOAM Meshing & Mesh Conversion | 2 | March 5, 2013 15:25 |
