January 18, 2018, 04:38 |
Multiple cellZones within rotor (AMI)
Benjamin
Rep Power: 12 |
Hey everyone
Hope I am in the right Sub-Forum with this. I am simulating a hydraulic dump with interDyMFoam/AMI (see also attached image), 3D. What I want to do is have the dump filled with water (setFields, cellZone) and then the whole part within the line "rotor" rotating. I set up the case with AMI, rotating and static part with gmsh. I am struggling with filling the hydraulic dump with water as an initial condition: I can define the whole volume within the "rotor-circle" as one cellZone (including the hydraulic dump) and then use the dynamicMeshDict to rotate. But then, I cannot define the "hydraulic dump" part only as a cellZone that I could fill with water with setFields. The other way would be to treat the hydraulic dump and the rest of the rotor as individual volumes, but then I have 2 cellZones that I need to rotate within my dynamicMeshDict. So my question: Is there a way to do this (without using MRF)? Many thanks! Ben setFields: Code:
regions ( zoneToCell { name "dump"; fieldValues ( volScalarFieldValue alpha.water 1 ); } ); Bonus question 2: How can I make the rotation not just a fixed velocity, but define an acceleration? |
January 19, 2018, 05:35 |
Just some quick hints. Not sure about the first part using multiple cellZones. Maybe you can instead use cellSets for the initialization and use the cellZone for the rigid body motion. For bonus question one: use -overwrite as option for the creation of the baffles For bonus question two: use a funtion1 type (a table for instance) Regards, Tom |
November 23, 2018, 05:25 |
Chayanit Nigaltia
Rep Power: 8 |
I am simulating a 2D pitching foil. I am using C mesh and using AMI. But I am not able to specify the moving cellZone. I using Gmsh mesh generator.
Regards Chayanit |
how to set periodic boundary conditions | Ganesh | FLUENT | 15 | November 18, 2020 06:09 |
[OpenFOAM.org] Install openFOAM 3.0.1 in Ubuntu 16.04 LTS from Deb packs | Pier84 | OpenFOAM Installation | 4 | June 18, 2016 16:22 |
[ICEM] Multiple edges | asal | ANSYS Meshing & Geometry | 2 | March 22, 2013 10:10 |
OpenFOAM static build on Cray XT5 | asaijo | OpenFOAM Installation | 9 | April 6, 2011 12:21 |
DecomposePar and CellZones | Anne Lincke | OpenFOAM | 4 | October 13, 2010 09:18 |
