November 26, 2017, 09:15 |
Dimensions in ScalarTransportFoam
Dan
Rep Power: 9 |
I have an simple question. I'm referring to OF 4.1. There is the definition of the equation: fvScalarMatrix TEqn ( fvm::ddt(T) + fvm::div(phi, T) - fvm::laplacian(DT, T) == fvOptions(T) ); So, this means: . For incompressible fluids phi means: . I don't get the dimensions right here. For the first term it's obviously . But for the second term phi has to be U, to get the right dimension. I looked up phi and it says: surfaceScalarField phi ( IOobject ( "phi", runTime.timeName(), mesh, IOobject::READ_IF_PRESENT, IOobject::AUTO_WRITE ), fvc::flux(U) ); So what exactly is meant with flux(U), is this without the area? I couldn't find the code definition of flux(U). I hope someone can help me to clarify this topic. Best regards Gesetzt |
November 27, 2017, 03:55 |
Rep Power: 12 |
December 3, 2017, 05:48 |
Dan
Rep Power: 9 |
Hey,
Thanks. I think it's clear now. Part of the problem was, that I didn't thought about the fact we are using FVM, so for the discretisation over all faces we need the area. Best Regards, Gesetzt |
February 16, 2018, 02:27 |
Ramana
Rep Power: 8 |
i have question about TEqn. can this be valid for porous simple foam also. |
scalartransportfoam |
Different dimensions for = dimensions : [0 2 -1 0 0 0 0] = [0 4 -3 0 0 0 0] | mohakbl111 | OpenFOAM Running, Solving & CFD | 5 | February 6, 2019 05:37 |
FOAM FATAL ERROR for Different dimensions | rupesh_w | OpenFOAM Running, Solving & CFD | 2 | April 27, 2016 04:14 |
Incompatible dimensions for operation | ruben23 | OpenFOAM Running, Solving & CFD | 2 | June 12, 2015 04:14 |
Software that can stretch the overall dimensions of a mesh. | Robert_B | Main CFD Forum | 2 | January 27, 2012 07:39 |
Units in scalartransportfoam | Frithjof | OpenFOAM | 1 | January 5, 2011 10:41 |
