lowReynold mesh and RNGkEpsilon
Old   March 13, 2018, 05:37
Default lowReynold mesh and RNGkEpsilon
Thijs
thijs1909 is on a distinguished road
Dear Foamers,
I have a question about near wall modelling using either RNGkEpsilon or realizableKE.
I created a lowReynold mesh of a pipe with a helix structure inside (imagine a ribbed pipe) with a y+~= 1 near the pipe wall.
I tested LaunderSharmaKE which is a lowRe turbulence model. The way I understand it, this model has damping functions build inside it, such that the wall boundary conditions can be set to:
k at wall = fixedValue (0)
epsilon at wall = zeroGradient.
But I want to try a different kEpsilon model such as realizableKE and RNGkEpsilon and still use a lowReynold mesh, because my mesh quality becomes bad if I use a y+~= 30 spacing near the wall such that I can use standard wall functions.
I read about enhanced wall treatment, but I think this is a term used in FLUENT. Anyway I think RNGkEpsilon and realizableKE can be used for a lowReynold mesh but I have to activate damping functions. If I use lowRe wallfunctions am I than applying dampingfunctions to my turbulence model? I am not sure?
Bc's at the wall, would look like this:
k @ wall = kLowReWallFunction
epsilon @ wall = epsilonWallFunction
nut @ wall = nutLowReWallFunction
Thanks in advance,
Thijs
thijs1909 is offline   Reply With Quote
kEpsilon and RNGkEpsilon not converging with second order schemes alpha23 OpenFOAM Running, Solving & CFD 1 September 2, 2015 10:47
Why RNGkepsilon model gives floating error shipman OpenFOAM Running, Solving & CFD 3 September 7, 2013 08:00
