Add a stop criteria for an unsteady multiphase simulation
Old   May 18, 2018, 09:22
Default Add a stop criteria for an unsteady multiphase simulation
Jeneas is on a distinguished road
Dear all
I'm working on a multiphase problem on twoPhaseEulerFoam on an air-water separator.
My problem become steady from a moment but i have to make a simulation process whe the piece can change.
So i don't know how to stop my simulation on the optimal iteration when she becomes steady.
I would like make a stop criteria on the average velocity on a patch if possible.
Do i have to use a writeAndEndSwakExpression? (i use OpenFoam 4x and swak4foam is not stable on this version)
I saw that we can use that function to look about the delta between the value of a probe at time t and the value of the same probe at time (t-dt). And when this delta become smaller than a fixed value, we can make than simulation stop.
This trick is possible on openfoam classic and for a patch instead of an probe?
I also tried using the tolerance in fvsolution but i don't understand all specificity. Are all tolerances need to be verify to stop the simulation? I tried to make all tolerance on a big value but that doesn't stop.
Thank you very much for your answers and have a good day!
Ps: Sorry for my bad english
Jeneas is offline   Reply With Quote
[PyFoam] and paraview eelcovv OpenFOAM Community Contributions 28 May 30, 2016 09:23
Thermal Simulation using Multiphase VOF model in Fluent hari.poudyal47@gmail.com Fluent Multiphase 0 July 20, 2015 11:31
Fan Curve Model with CHT simulation mariconeagles96 CFX 5 April 22, 2015 01:31
MRF Solver fan simulation - problem sivakumar FLUENT 0 February 15, 2013 03:26
Simulation and Optimisation of centrifugal fan 3D to 2D eRzBeNgEl STAR-CCM+ 0 January 31, 2013 13:21
