Accessing the value of a field variable
Old   June 23, 2018, 11:01
Default Accessing the value of a field variable
charles4allme is on a distinguished road
I have looked at the forums and have found solutions but I want to be sure that I am correct. I am trying to access the value of velocity during each time step to calculate losses in a ventilation duct. Here is the form that I have written it in:
const volVectorField& Uduct = U.db().lookupObject<volVectorField>("U");
Uduct is what I would input into my equation for calculating the duct losses. Is that the right way of setting it up. I appreciate any input.
Thanks
charles4allme is offline   Reply With Quote
Old   June 23, 2018, 16:15
Norbert Weber
dl6tud is on a distinguished road
Your questions is difficult to understand. From where do you need to access the velocity? In a boundary condition? In the solver itself? In a post-processing tool?
dl6tud is offline   Reply With Quote
Old   June 25, 2018, 08:15
HI thanks,
From the solver itself. So what ever value of U in the time step, it looks it up and gets the value. Is that possible?
Old   June 25, 2018, 08:26
Norbert Weber
U
only "U"
Info << U << endl;
Old   June 25, 2018, 15:06
Alright thanks.
Is it possible to use the values at each time step to update the values for the reynolds number. I need the value for the reynolds number to calculate the flow loss. I assumed my earlier code would do that but at the moment all I think it does is take the initial velocity value.
Thanks.
Old   June 25, 2018, 17:07
Mark Olesen
olesen will become famous soon enougholesen will become famous soon enough
Thanks
Actually your code snippet makes very little sense (or it suffered from transcription problems).
If we really start with this:
The "U" part is presumably already the velocity field. The "db()" part gets you the objectRegistry used by "U", which means your mesh. From this the "lookupObject" finds the named object of the specified type. Which seems like you've gone once around to come up with a reference to your starting point??
If you want to calculate a Reynolds number or something, having the entire velocity field throughout the volume probably won't help much. It might be more useful to use a sampling plane or a sampling patch combined with an area average to obtain a representative value.
Can't say offhand where you want to proceed from there (how to get a length scale, which rho, mu, etc) - it's not really obvious from your post what data or geometry you have.
/mark
olesen is offline   Reply With Quote
Old   June 26, 2018, 06:45
/mark
I would go with your suggestion to calculate the Reynolds number. I have all other variables except the length scale on this occassion . I have attached the geometry. Its a simple case of flow through a ventilation duct with an initial velocity of 10m/s. The dimension of the duct is 0.4m x 0.4m x 3m.
Thanks.
Old   June 17, 2020, 16:36
René Thibault
Tibo99 is on a distinguished road
What would be the code line to access to the variable field 'k', let say at every cells center of the domain, but from the file fvOptions?
I try to find an example of how to achieve that and I find nothing.
Thank!
Best Regards,
Tibo99 is offline   Reply With Quote
[Other] dynamicTopoFVMesh and pointDisplacement RandomUser OpenFOAM Meshing & Mesh Conversion 6 April 26, 2018 07:30
Compare field variable in two cells upuli OpenFOAM Programming & Development 0 July 24, 2017 01:06
Help solving "c dot inv(A)" after solving the field variable (Ax=b) Logan Page OpenFOAM Programming & Development 0 September 11, 2014 07:57
field function to point variable temperature Trofrensis STAR-CCM+ 1 November 25, 2009 00:46
field variable macro of the mean-x-velocity? zt xie FLUENT 2 November 15, 2005 05:48
