July 1, 2018, 23:37 |
mesh missing after snap step
ALLEN
Rep Power: 11 |
Hello,everybody,
I have got stuck in the snappyHexMesh for a long time, the problem is as follows. I am trying to simulate a vertical axis wind turbine using AMI in OpenFOAM. The picture below explicitly show the half domain in the vertical direction together with the foil and the AMI setup. halfMesh.jpg and the AMI part (blue) composes of actually the surfaces of a hollow cylindrical stuff, as can be seen: AMI.png After setting up the geometry, the castellatedMesh step began, and everything looks fine, I can get the mesh between the AMI surfaces, like this: castellatedStep.jpg Then I tried snappyHex Step, but after complicated manipulation, the result turns out that there are mesh missing inside the AMI zone, around the place where coarse mesh meets the fine mesh as shown in below: snappyStep.jpg I have tried a lot to solve this problem by changing the parameters in the snappyHexMeshDict concerning the snap step and castellatedMesh step, but I couldn't work it out. Could someone have some comments and suggestions on this problem? it will be greatly appreciated for that. I have attached the snappyHexMeshDict in this thread, so you can have a look at it. Any comments are quite valuable for me. Thanks in advance! Allen BTW: when the snappyHexMesh goes into the snappyStep, there are a lager lot of warnings, like: Code:
--> FOAM Warning : From function void Foam::snappySnapDriver::calcNearestFace(Foam::label, const indirectPrimitivePatch&, const scalarField&, Foam::vectorField&, Foam::vectorField&, Foam::labelList&, Foam::vectorField&) const in file snappyHexMeshDriver/snappySnapDriverFeature.C at line 333 Did not find surface near face centre (0.171302 0.138639 -0.0705999) snappyHexMeshDict.txt |
July 14, 2018, 12:43 |
Peter Hess
Rep Power: 16 |
Hello!
Would you please post the case with the stl files! Regards Peter |
snammyhex |
pimpleDyMFoam computation randomly stops | babapeti | OpenFOAM Running, Solving & CFD | 5 | January 24, 2018 05:28 |
Micro Scale Pore, icoFoam | gooya_kabir | OpenFOAM Running, Solving & CFD | 2 | November 2, 2013 13:58 |
How to write k and epsilon before the abnormal end | xiuying | OpenFOAM Running, Solving & CFD | 8 | August 27, 2013 15:33 |
IcoFoam parallel woes | msrinath80 | OpenFOAM Running, Solving & CFD | 9 | July 22, 2007 02:58 |
Could anybody help me see this error and give help | liugx212 | OpenFOAM Running, Solving & CFD | 3 | January 4, 2006 18:07 |
