How to use 2 tableFile?
Old   August 21, 2018, 15:59
Default How to use 2 tableFile?
Ignacio Sarmiento
IgnacioSarmientoINH is on a distinguished road
There is a boundary condition called oscillatingFixedValue, there is a tutorial about it too, using this bc you can assign time varying amplitude and frequency, but if you try to assign both as:
inlet
type oscillatingFixedValue;
amplitude tableFile;
tableFileCoeffs
fileName "$FOAM_CASE/a.data";
frequency tableFile;
tableFileCoeffs
fileName "$FOAM_CASE/f.data";
OpenFoam doesn't recognize both at the same time, and only recognize the last tableFileCoeffs so in the next time step the output says:
inlet
value uniform (1.10955 0 0);
refValue uniform (1 0 0);
offset (0 0 0);
tableFileCoeffs
tableFileCoeffs
Am I doing something wrong?
I know I could just write several tables, but I'm working in a boundary with a lot o data, and groovyBC doesn't seems to have problems using several tableFiles, we can't do the same?
IgnacioSarmientoINH is offline   Reply With Quote
Old   August 23, 2018, 07:23
Ignacio Sarmiento
I just realized the problem exists only in old versions of OP~
In the old versions it says:
<entryName> tableFile;
tableFileCoeffs
dimensions [0 0 1 0 0]; // optional dimensions
fileName dataFile; // name of data file
outOfBounds clamp; // optional out-of-bounds handling
interpolationScheme linear; // optional interpolation method
and in the new ones its like:
<entryName>Coeffs
at somepoint they realized~
my bad
data entry, oscillatingfixedvalue, tablefile
reading timeseries into the solver-Problem with using dataEntry sina.s OpenFOAM Running, Solving & CFD 0 March 17, 2016 04:30
volumetricFlowRate tableFile fengjq OpenFOAM Running, Solving & CFD 2 November 6, 2015 09:08
import tableFile to OF kpax OpenFOAM Programming & Development 2 October 8, 2012 06:49
