Velocity as a function of height - Boundary condition.
Like Tree1Likes
  • 1 Post By senthilathiban
Old   August 21, 2018, 08:37
Default Velocity as a function of height - Boundary condition.
SSA
senthilathiban is on a distinguished road
Hi all,
I am modelling a flow through a wind tunnel and I need to set my inlet velocity as a function of height of the wind tunnel. (Velocity increases as height increases).
Is there any way to do it.
P.S: I am using Openfoam 4.0 and I think the groovyBC doesn't work.
senthilathiban is offline   Reply With Quote
Old   August 21, 2018, 12:29
clapointe is on a distinguished road
There are a number of ways to do this. I believe that I've previously compiled swak4Foam for OF4. If you don't want to use groovy bc, then a fixedProfile boundary condition will work -- you can define a functional form or read velocities (as a function of height) from a csv. Information on how to do this can be found here : https://github.com/OpenFOAM/OpenFOAM...FvPatchField.H.
Caelan
clapointe is offline   Reply With Quote
Old   August 22, 2018, 09:46
SSA
Hi clapointe, Thanks for the info. I also found another way to do this. I got the cell location from writecellcentres command and then I calculated the velocity for each point and fed into the inlet as nonuniform list.
thanks once again for your quick reply.
hmusaddiq likes this.
Old   March 25, 2019, 08:34
Default Hamza
HM
hmusaddiq is on a distinguished road
Hello Senthilathiban,
Did you manually calculated the velocity and then manually add it in the 0.U file?
I am also having the same problem.
hmusaddiq is offline   Reply With Quote
Old   March 25, 2019, 11:01
SSA
Yes I calculated manually. But later I found another boundary condition fixedProfile
More infor at https://www.youtube.com/watch?v=rfNYVqU1py4&t=
Problem in setting Boundary Condition Madhatter92 CFX 12 January 12, 2016 04:39
Running UDF with Supercomputer roi247 FLUENT 4 October 15, 2015 13:41
Low Mixing time Problem Mavier CFX 5 April 29, 2013 00:00
Velocity inlet boundary condition for porous medium Chander CFX 3 March 11, 2012 21:18
vorticity boundary condition bearcharge Main CFD Forum 0 May 14, 2010 11:32
