How to use 2 tableFile?
There is a boundary condition called oscillatingFixedValue, there is a tutorial about it too, using this bc you can assign time varying amplitude and frequency, but if you try to assign both as:
inlet { type oscillatingFixedValue; amplitude tableFile; tableFileCoeffs { fileName "$FOAM_CASE/a.data"; } frequency tableFile; tableFileCoeffs { fileName "$FOAM_CASE/f.data"; } } OpenFoam doesn't recognize both at the same time, and only recognize the last tableFileCoeffs so in the next time step the output says: inlet { type oscillatingFixedValue; value uniform (1.10955 0 0); refValue uniform (1 0 0); offset (0 0 0); amplitude tableFile; tableFileCoeffs { fileName "$FOAM_CASE/f.data"; } frequency tableFile; tableFileCoeffs { fileName "$FOAM_CASE/f.data"; } } Am I doing something wrong? I know I could just write several tables, but I'm working in a boundary with a lot o data, and groovyBC doesn't seems to have problems using several tableFiles, we can't do the same? |
I just realized the problem exists only in old versions of OP~
In the old versions it says: <entryName> tableFile; tableFileCoeffs { dimensions [0 0 1 0 0]; // optional dimensions fileName dataFile; // name of data file outOfBounds clamp; // optional out-of-bounds handling interpolationScheme linear; // optional interpolation method } and in the new ones its like: <entryName> tableFile; <entryName>Coeffs { fileName dataFile; // name of data file outOfBounds clamp; // optional out-of-bounds handling interpolationScheme linear; // optional interpolation method } at somepoint they realized~ my bad |
