KinematicCloud - inject particles each and every second. |
August 22, 2018, 09:56 |
SSA
Rep Power: 8 |
Hi all,
I am trying to study the movement of particles inside a wind tunnel. My kinematicCloudProperties looks as follows. Code:
injectionModels { model1 { type manualInjection; positionsFile "kinematicCloudPositions"; duration 1000; parcelsPerSecond 100; massTotal 0; parcelBasisType fixed; flowRateProfile constant 1; nParticle 10; SOI 1; U0 (0 0 0); sizeDistribution { type fixedValue; fixedValueDistribution { value 0.0000025; } } } } What should I change in the code. Can anyone please help. |
August 22, 2018, 17:26 |
#2 | |
Ali Shayegh
Rep Power: 10 |
Hi I myself, prefer kinematicLookupTableInjection instead of manualInjection. It handles what u want; It also needs one more file named parcelInjectionProperties in constant directory that comes in the following. The following files are my setting for 8 injectors aligned in z direction: kinematicCloudProperties: Code:
injectionModels { model1 { massFlowRate .0001; parcelInjectionProperties (mDot entry is of no importance.) : Code:
Ali |
August 28, 2018, 06:10 |
SSA
Rep Power: 8 |
Hi Ali, I have used this kinematic lookup table and the problem now is, the simulation suddenly stops and shows no error.
the last line in the terminal is ''solving kinematic cloud'' and there is no error, it doesn't stop. it's just stuck at this point. do you have any idea, why this happens. thanks, Senthil. |
December 7, 2019, 04:09 |
Rep Power: 6 |
senthilathiban do you habe a solution for your problem? because I have now the same problem and no idea.
December 7, 2019, 06:04 |
SSA
Rep Power: 8 |
There were problems when you run in parallel with openfoam 4. The kinematiccloud was not able to transfer data within processors.
I upgraded to openfoam 5 and then it worked fine. |
December 10, 2019, 15:29 |
Rep Power: 6 |
okay that's sounds easy. I try to do the same but there is no positive result. First when I used the patch injection the simulation worked. Now I'm using kinematicLookUpTableInjection and I have the problem. Maybe someone has an idea?
