October 19, 2018, 13:18 |
Air Foil 2 D case
Arslan
Rep Power: 8 |
Dear All,
I hope this message finds you in best of health and spirit. I am doing simulation for airfoil 2D case using snappyHexMesh. I am a little bit confused about type of computational domain. My airfoil is stationary and i have meshed it using snappyHexMesh. For 0 angle of attack square domain will work. If i want the airfoil to be at the same place for next angle of attack which is 5, so if i give in velocity vector (vcos5 and vsin5), the angle would be still zero or 5(square domain)? Is it compulsory to make a C domain then only i could work at different angle of attack.? |
October 29, 2018, 09:21 |
Zander Meiring
Rep Power: 7 |
By using vertical and horizontal components for the inlet velocity, the result becomes more dependent on the top and bottom boundaries. It might be better to rather remesh the foil at different attack angles.
Furthermore, I would personally recommend using blockMesh rather for an airfoil shape, as you're likely to get a better quality mesh. |
November 6, 2018, 13:12 |
3d wing
Arslan
Rep Power: 8 |
Hello all, i am working on 3D wing at 5 degree in square computational domain. I have small doubt regarding velocity vectors and lift and drag directions. As i have given 5 degrees to my wing in CAD. My inlet velocity is 1 m/s. Now do i need to give velocity also in x and y or (1 0 0) will work. Same question for lift and drag direction.
airfoil 2d, airfoil 3d, computational domain, snappy hex mesh |
Data Center Air conditioning Boundary Condition problem | jaypatel | OpenFOAM | 9 | April 8, 2020 15:04 |
Radiation interface | hinca | CFX | 15 | January 26, 2014 17:11 |
problem is modeling and simulation of an air foil | alnabhani | CFX | 4 | December 2, 2010 13:24 |
Solver for a Rotatinng Disc in a Volume of Air | alcesalces | Main CFD Forum | 0 | August 19, 2009 14:33 |
Free surface boudary conditions with SOLA-VOF | Fan | Main CFD Forum | 10 | September 9, 2006 12:24 |
