November 9, 2018, 02:14 |
OpenFOAM Circular Flow for Cornering Vehicle
V
Hello, I am relatively new to using OpenFOAM for the aerodynamics of my FSAE team and have become fairly comfortable with the setup, running, and constructing a multi-block blockMesh for steady-state flow over the car. I have successfully run many simulations on various parts of the aerodynamic components of the racecar using uniform, head on flow.
However, the next thing I want to try and tackle is simulation over the car during cornering. My current assumption is that I cannot simply place the car slightly yawed in the domain and should instead try to assign a curvature to the inlet velocity. I can construct a semi-circular blockMesh, but am struggling to figure out how to actually assign circular boundary conditions for the flow itself. Are there any built in methods to accomplishing this? If so, any help, guidance, and ideas would be greatly appreciated! |
November 9, 2018, 02:41 |
Anton Kidess
Rep Power: 29 |
Completely ignoring what OpenFOAM can or cannot do, how would you mathematically describe a circular boundary condition on a surface? It's impossible.
Make a sketch of what you want your flow field to look like, and then think about what this means for the boundaries.
*On twitter @akidTwit *Spend as much time formulating your questions as you expect people to spend on their answer. |
OpenFOAM 4.0 Released | CFDFoundation | OpenFOAM Announcements from OpenFOAM Foundation | 2 | October 6, 2017 05:40 |
Can not achieve statistically steady flow in Openfoam | jiaodanuma | OpenFOAM | 0 | August 16, 2016 06:49 |
OpenFOAM Training, London, Chicago, Munich, Sep-Oct 2015 | cfd.direct | OpenFOAM Announcements from Other Sources | 2 | August 31, 2015 13:36 |
Two-phase flow in a circular horizontal pipe | DmitryS | Fluent Multiphase | 0 | May 17, 2014 16:22 |
Can OpenFOAM generate flow at the speed of light? | Michel_sharp | OpenFOAM | 6 | October 24, 2009 04:09 |
