Solid-Solid thermal resistance layer thickness
Old   November 12, 2018, 07:41
Default Solid-Solid thermal resistance layer thickness
Adam
Adam_K is on a distinguished road
It looks like the correct way to handle the interface between two solid regions is with the compressible::turbulentTemperatureCoupledBaffleMix ed type BCs, as seen in the multiRegionHeater tutorial and several posts here but I still have a question about their implementation.
In the extended code guide/examples, I see:
Usage
Property	Description	Required	Default value
Tnbr	name of the field	no	T
thicknessLayers	list of thicknesses per layer [m]	no
kappaLayers	list of thermal conductivities per layer [W/m/K]	no
kappaMethod	inherited from temperatureCoupledBase	inherited
kappa	inherited from temperatureCoupledBase	inherited
My boundary condition is the following
-K*(dT/dr) evaluated at the surface of the particle = (T_surface-T_matrix)/Resistance
Are the thicknessLayers and kappaLayers themselves important? Or are they just used to calculate the coupling between the two surfaces? For example, if I have 10 µm radius particles and I know the inter-facial resistance with the matrix is 0.1 (m²*K)/W is there a difference between the two cases.
Case A
thicknessLayers (1e-6) [m]
kappaLayers (1e-5) [W/m/K]
Case B
thicknessLayers (1e-7) [m]
kappaLayers (1e-6) [W/m/K]
Adam_K is offline   Reply With Quote
Old   November 13, 2018, 05:25
TobM is on a distinguished road
Should be the same.
TobM is offline   Reply With Quote
Old   November 14, 2018, 23:56
Adam
Originally Posted by TobM View Post
Should be the same.
I think you're right. There was no difference between two simulations I ran with
thicknessLayers	(1);
kappaLayers	    (1e2);
and
thicknessLayers	(1e-9);
kappaLayers	    (1e-7);
Error - Solar absorber - Solar Thermal Radiation MichaelK CFX 12 September 1, 2016 05:15
THERMAL CONDUCTIVITY FOR SOLID DOMAIN -BOUYANCY CARL CFX 1 June 9, 2006 16:44
errors Fahad Main CFD Forum 0 March 23, 2004 13:20
boundary layer thickness 98.4F Main CFD Forum 1 December 29, 2000 07:23
Info: Short Course On Thermal Design of Electronic Equipment Arnold Free Main CFD Forum 0 August 10, 1999 10:18
