Torque on rotating rotors in a closed chamber |
November 17, 2018, 17:26 |
Vinod Bansal
Hi, I'm trying to find out how to solve the problem of finding the torques on two rotors rotating at fixed speeds in a small chamber of fluid. Like two impellers side by side in a small chamber of enclosed fluid.
So far I have found SRFSimpleFoam but that only supports one rotor from what I can understand. I have searched day and night for this and I'm mentally and physically exhausted. I would appreciate some help here. |
November 19, 2018, 03:56 |
Zander Meiring
Rep Power: 7 |
Use multiple reference frame (MRF) zones. There is a tutorial case in the simpleFoam folder called rotor disc that demonstrates it's use. As I understand it, you will want to make two cell zones around the two different impellers. Then in an MRF file inside your constant folder, you will set up the rotational speed of each of these zones. What this does is adds the Coriolis effect inside of these zones as well as change any boundary condition in the zone to be in the rotating reference frame.
Once you have that, set up a forces calculation. For this, see the documentation documentation: https://www.openfoam.com/documentati...es-forces.html |
Can SU2-6.0.1 do RANS + Rotating Mesh simulations for helicopter rotors? (Bug?) | adrisabate | SU2 | 0 | July 20, 2018 08:08 |
Decomposition simulation of solid material in closed chamber | Ambrosio | FLUENT | 1 | May 11, 2018 04:37 |
Car external aerodynamic with wheel spinning issue | hokhay | FloEFD, FloWorks & FloTHERM | 2 | August 18, 2016 04:23 |
Closed rotating tank with free surface | Juan Catelén | CFX | 1 | October 10, 2007 18:59 |
Rotating chamber | DS | FLUENT | 0 | February 23, 2005 11:04 |
