December 2, 2018, 08:29 |
snappyHexMesh-flow over sphere
Goind Sharma
Rep Power: 7 |
Hi All,
I am trying to simulate flow over sphere and meshing with snappyHexMesh. I have stl file for sphere. snappyhexMesh working fine and not getting error but desired mesh is not generating. I am attaching snappy.txt which is the mine input for snappyhexMeshDict. Regards, Govind Sharma PhD, IIT Delhi |
December 2, 2018, 13:12 |
anonymous
Rep Power: 14 |
Hi!
Can you share your log file? Or give more details about the problem? Your locationInMesh coordinate is correct? If it is, try with locationInMesh (-2.899 0.11199 0.04499); Make sure the point is not on an internal face. |
December 3, 2018, 08:40 |
#3 | |
Goind Sharma
Rep Power: 7 |
Thanks, Here I have attached the output of snappyHexMesh. Also I am sharing the output of snappyHexMesh. Govind |
December 3, 2018, 08:52 |
anonymous
Rep Power: 14 |
Hmm... Why do you have that much time directories?
make sure you check the last time directory with paraview, and you start snappy from the mesh resulted by blockMesh! And now what is your problem exactly? (I see there are no layers, but I'm not sure if this is the only problem.) I think you should increase the refinementLevel for the sphere. And you should have the sphere inside the refinement box. The layer generation in snappy can be really painful. For the first step try with only a few layers with the "relativeSizes true;" option. Then you can increase it but don't worry if you won't be able to generate exactly the same mesh what you want. As I mentioned layer generation in snappy can be pretty painful! |
December 4, 2018, 04:28 |
ssa
Rep Power: 7 |
December 4, 2018, 05:10 |
anonymous
Rep Power: 14 |
refineMesh and snappy do nearly the same if you refine in 3D. But why should you use 2 utility when you can do everything in one?
Just correct the coordinates of the refinementBox and increase the refinementLevel of the sphere and you will be fine. |
Issues on the simulation of high-speed compressible flow within turbomachinery | dowlee | OpenFOAM Running, Solving & CFD | 11 | August 6, 2021 06:40 |
Water Sphere reacting to flow of air modelling | Jacee | FLUENT | 0 | May 25, 2018 09:29 |
Symmetry Boundary Condition for Flow Past a sphere | Qkarl | Main CFD Forum | 14 | March 6, 2018 03:32 |
Flow past a sphere | Fabio | FLUENT | 23 | December 18, 2009 15:32 |
3D sphere flow | MH Kim | Main CFD Forum | 1 | August 8, 2005 17:06 |
