How to define multiple ranges for JANAF coefficients? (OF5/OF6)
1 Attachment(s)
I am accessing the CEA database of NASA for JANAF coefficients beyond the typical range of 200-6000 K. CEA data is expressed in 3 different ranges 200-1000, 1000-6000, 6000-20000 (see attached image for H2). How do I incorporate three ranges in thermodynamics subdictionary? Is there any way? If not is there any alternative? Does something like this work? Code:
thermodynamics |
hey deepbandivadekar,
Bad news first: I quickly checked the OFv6 implementation of the Janaf polynomials (https://cpp.openfoam.org/v6/janafThermo_8H_source.html) and it doesn't seem compatible. Now the good news: It shouldn't be too complicated to implement this functionality in an extra class (ThreeRangeJanafThermo - this is the one you need to implement, basically like janafThermo but with some more if-statements and of course one coeffArray more for the mid range). This class and the mandatory myPsiThermos.C-file* (including your new class into the makeThermo-macros) should be compiled into a new library, which can then be linked to your application through your controlDict. I know it is quite vague (I'm super tired) but I think you can make it work by searching a bit through the forums and digging into the code. I wish you good luck! Cheers RP *myPsiThermos.C or myRhoThermos.C, refering to the type of thermodynamics used in your application. |
So it'd rather be like this: Code:
thermodynamics Thanks! |
Yes, something like this is a good starting point, even though the final version will depend on how you implement it.
