decomposePar and mapFields not working as expected |
February 14, 2019, 20:44 |
TWB
Rep Power: 19 |
I'm going for a low res case to a higher res case, interpolating data from the low res to the high res using mapFields. I use: mpirun -n 1 mapFields ../source_dir/ -consistent -sourceTime 0.0004000007 Things seems to work fine and I got the directory 0.0004000007 filled with updated variables in binary format. Previous, they were fill with variables from time = 0. Then I use decomposePar to decompose the data. Things ended successfully but when I check the variables inside the processor* dir, I realised that they were filled with ith variables from time = 0, not the binary data which I should be getting. May I know why this is so? Did I make an error somewhere? Thanks! |
February 15, 2019, 02:54 |
anonymous
Rep Power: 14 |
Hi!
What if you try with "decomposePar -latestTime" ? |
February 15, 2019, 08:06 |
TWB
Rep Power: 19 |
Hi simrego,
Thanks for the reply. I also tried this but strangely, it didn't work. I tried for a smaller case and it work nicely. I wonder why. |
Problem with decomposePar (and mapFields) for large problem | quarkz | OpenFOAM Pre-Processing | 2 | February 21, 2019 09:51 |
Problems with decomposePar and mapFields | Fischlurch | OpenFOAM Running, Solving & CFD | 2 | October 7, 2016 07:51 |
implementation of mapFields into parallel transient case | simpomann | OpenFOAM Pre-Processing | 4 | August 2, 2016 04:41 |
mapFields : mpirun gives segmentation fault | vanihba2000 | OpenFOAM Pre-Processing | 1 | October 13, 2015 12:07 |
transientSimpleDyMFoam, mapFields and decomposePar | pad | OpenFOAM Running, Solving & CFD | 0 | December 3, 2010 05:22 |
