flowRateInletVelocity for multiple patches
Old   March 25, 2019, 05:49
Default flowRateInletVelocity for multiple patches
Mattia
time- is on a distinguished road
I have a question and I'm sure is something that can be checked in the source code, but I'm not that confident with C++ so please don't mind if this sound extremely stupid
Is flowRateInletVelocity suitable in the case my inlet is made of multiple surfaces grouped together in a single patch (check sample image, colored faces are inlet).
What I mean is if the BC will divide the flowrate by all the inlet faces, resulting in a constant velocity value, equal for all patches even if there are walls in between the inlets. I hope I did explain clearly enough.
I think this won't work, but I would like to ear your opinion.
If this is not the case, with regex I should be able to keep all the inlet separated and this should work. At this point I was wondering if using extrapolateProfile flag will produce a parabolic profile for every single patch.*
Bye
* I saw here that velocity profile is uniform and not parabolic. Nevermind.
time- is offline   Reply With Quote
Old   March 26, 2019, 10:40
Alexey Matveichev
alexeym has a spectacular aura aboutalexeym has a spectacular aura about
Send a message via Skype™ to alexeym
flowRateInletVelocity calculates area of a patch (using simple sum of face areas), divides volumetric flow rate to calculate velocity, and then sets this value at every patch face. In general, boundary condition knows nothing about "walls in between inlets".
alexeym is offline   Reply With Quote
Old   April 21, 2019, 11:40
Joachim Herb
jherb is on a distinguished road
If you look at the source code of the boundary condition, you see what extrapolateProfile does:
https://github.com/OpenFOAM/OpenFOAM...orField.C#L161
It takes the values from the cell centers of the cells at the boundary and scales them, so the overall flowrate is equal to the requested value.
So what ever your flow profile is in the flow domain, it will be projected (and adopted) to the boundary faces.
jherb is offline   Reply With Quote
Foam::error::PrintStack almir OpenFOAM Running, Solving & CFD 92 May 21, 2024 08:56
Problem using AMI vinz OpenFOAM Running, Solving & CFD 298 November 13, 2023 09:19
Possible bug with stitchMesh and cyclics in OpenFoam Jack001 OpenFOAM Pre-Processing 0 May 21, 2016 09:00
Case running in serial, but Parallel run gives error atmcfd OpenFOAM Running, Solving & CFD 18 March 26, 2016 13:40
[blockMesh] Merging edge patches Yosmcer OpenFOAM Meshing & Mesh Conversion 11 November 16, 2014 15:51
