Problems with setFields
Old   March 25, 2019, 10:58
Default Problems with setFields
Paul
pbOPEN is on a distinguished road
Hi all,
I am having difficulties with the setFields function. I am attempting to run a modified damBreak example, but I am unable to properly initialize water where I want it.
To make the modified mesh, I copied the damBreak tutorial to my run directory, and made some small edits to the mesh. After running blockMesh and modifying setFieldsDict, I attempted to run setFields. It successfully ran with no errors, however, the water is only appearing on the walls of my mesh (with no water in the interior). I have attached a picture of what I am seeing in paraFoam.
I have tried troubleshooting this in various ways. I completely rewrote setFieldsDict, I copied alpha.water.orig to alpha.water before running setFields, etc. I am still unable to properly set water where I want it.
Any help you can provide would be much appreciated and if you need anything else from me, just let me know.
Thank you.
pbOPEN is offline   Reply With Quote
Old   March 26, 2019, 09:28
Alexey Matveichev
alexeym has a spectacular aura aboutalexeym has a spectacular aura about
Send a message via Skype™ to alexeym
A bit of context would be nice. Could you post "some small edits to the mesh"?
Could you post your setFieldsDict modifications?
alexeym is offline   Reply With Quote
Old   March 26, 2019, 10:23
Paul
Originally Posted by alexeym View Post
Yes, thank you for the help.
Here is my blockMeshDict:
  \\      /  F ield         | OpenFOAM: The Open Source CFD Toolbox
   \\    /   O peration     | Website:  https://openfoam.org
    \\  /    A nd           | Version:  6
     \\/     M anipulation  |
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
    object      blockMeshDict;
convertToMeters 0.001;
vertices
    (0 0 0)
    (60 0 0)
    (60 44.45 0)
    (0 44.45 0)
    (0 21.825 0)
    (0 22.625 0)
    (-10 22.625 0)
    (-10 21.825 0)
    (0 0 1)
    (60 0 1)
    (60 44.45 1)
    (0 44.45 1)
    (0 21.825 1)
    (0 22.625 1)
    (-10 22.625 1)
    (-10 21.825 1)
    (60 21.825 0)
    (60 21.825 1)
    (60 22.625 0)
    (60 22.625 1)
blocks
    hex (0 1 16 4 8 9 17 12) (20 20 1) simpleGrading (1 1 1)
    hex (4 16 18 5 12 17 19 13) (20 5 1) simpleGrading (1 1 1)
    hex (5 18 2 3 13 19 10 11) (20 20 1) simpleGrading (1 1 1)
    hex (4 5 6 7 12 13 14 15) (5 5 1) simpleGrading (1 1 1)
edges
boundary
    leftWall
	type wall;
	faces
	    (0 8 12 4)
	    (5 13 11 3)
	    (7 15 14 6)
	    (6 14 13 5)
	    (3 11 10 2)
	    (0 1 9 8)
            (4 12 15 7)
    atmosphere
        type patch;
        faces
            (16 18 19 17)
	    (18 2 10 19)
	    (1 16 17 9)
	    (0 4 16 1)
	    (4 5 18 16)
	    (5 3 2 18)
	    (8 9 17 12)
	    (12 17 19 13)
	    (13 19 10 11)
	    (7 6 5 4)
	    (15 12 13 14)
mergePatchPairs
And here is my setFieldsDict:
     \\/     M anipulation  |
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
    location    "system";
    object      setFieldsDict;
defaultFieldValues
    volScalarFieldValue alpha.water 0
regions
    boxToCell
        box (0 0 -0.02) (0.05 0.018 0.02);
        fieldValues
            volScalarFieldValue alpha.water 1
I do not believe I changed anything else from the damBreak tutorial (which may be the reason I'm having trouble). Thank you again
dambreak, setfields, setfieldsdict
[ICEM] Problems with coedge curves and surfaces tommymoose ANSYS Meshing & Geometry 6 December 1, 2020 11:12
rhoSimplecFoam with setFields sino75 OpenFOAM Pre-Processing 0 March 11, 2015 04:08
Needed Benchmark Problems for FSI Mechstud Main CFD Forum 4 July 26, 2011 12:13
Two-phase air water flow problems by activating Wall Lubrication Force challenger85 CFX 5 November 5, 2009 05:44
Help required to solve Hydraulic related problems aero CFX 0 October 30, 2006 11:00
