How to select faces on a plane?
Old   March 26, 2019, 15:29
Default How to select faces on a plane?
miragemobile is on a distinguished road
TLDR: How do I create a patch from faces along a specified plane? The plane is an external area of the domain?
I am working with faces that lie on a single plane. I am trying to combine these faces into a single faceSet/patch to define a boundary condition.
All of these faces are currently part of different patches.
To my understanding (please correct if wrong), I need to use topoSetDict and createPatchDict and maybe something with setSet and surfaceToFace or surfaceToCell or boundaryToFace.
I've tried boundaryToFace, but it combined all exterior faces into 1 faceSet. I would like to have multiple exterior faceSets.
I've seen the example below:
name heaterCellSet;
type cellSet; //faceSet;
action new;
source boxToCell; //boxToFace;
sourceInfo
box (-0.01001 0 -100 )(0.01001 0.00999 100);
However, this requires a box to be specified around the cells/faces. For faces, it seems more natural to specify a plane.
Is there a method that doesn't involve using boxToFace? I seem to get the error message 'Face X is not external to the mesh', even though my box dimensions appear to only encapsulate one cell width.
miragemobile is offline   Reply With Quote
Old   March 26, 2019, 15:42
Visually,
How would one perform this grouping of exterior faces on the flat and curved faces of a cylindrical slice?
The boxToFace would not be able to encompass all exterior faces without also encompassing interior cells...
Old   March 31, 2019, 17:38
Peter Hess
peterhess is on a distinguished road
Hello Miragemobile!
I cant give you direct answer, anyway I can suggest the following source:
https://openfoamwiki.net/index.php/TopoSet
See: 5 List of sources
Regards
Peter
peterhess is offline   Reply With Quote
Old   April 1, 2019, 15:17
Originally Posted by peterhess View Post
Hello Miragemobile!
Regards
Peter
Thank you Peter!
normalToFace could be beneficial for my selection of faces along planes.
surfaceToCell could be beneficial for my selection of faces along a curved surface. I wonder if the STL can just be an open surface or if it has to be closed.
I will try these out.
Mirage
Old   April 1, 2019, 17:07
Two more questions:
1. normalToFace obviously collects all faces normal to a given plane (including interior faces). I am looking to collect only exterior faces. I am considering using boundaryToFace, followed by normalToFace. However I am not sure how to use the functions on an existing faceSet and not the entire domain.
2. Does anyone know if surfaceToCell requires a closed surface?
Decomposing meshes Tobi OpenFOAM Pre-Processing 22 February 24, 2023 09:23
[snappyHexMesh] Error snappyhexmesh - Multiple outside loops avinashjagdale OpenFOAM Meshing & Mesh Conversion 53 March 8, 2019 09:42
Compressor Simulation using rhoPimpleDyMFoam Jetfire OpenFOAM Running, Solving & CFD 107 December 9, 2014 13:38
foam-extend_3.1 decompose and pyfoam warning shipman OpenFOAM 3 July 24, 2014 08:14
[ICEM] Export ICEM mesh to Gambit / Fluent romekr ANSYS Meshing & Geometry 1 November 26, 2011 12:11
