(OpenFoam) outlet velocity boundary condition depending on outlet pressure (PUMP)
Like Tree1Likes
  • 1 Post By Tobi
Old   March 27, 2019, 03:23
Default (OpenFoam) outlet velocity boundary condition depending on outlet pressure (PUMP)
stefano zinna
giordy is on a distinguished road
Hi All,
I would like to simulate how a pump work when it suck air from a vessel. In particular I am interested in the boundary condition at outlet of the vessel where the air is sucked with a velocity that depends on the pressure at outlet. Is there any boundary condition in OpenFoam that I can use for it?
Thanks.
regards,
Stefano
giordy is offline   Reply With Quote
Old   March 28, 2019, 06:23
Lucky
fanPressure?
Old   March 28, 2019, 06:28
Tobi's Avatar
Tobias Holzmann
Tobi has a spectacular aura aboutTobi has a spectacular aura aboutTobi has a spectacular aura about
Send a message via ICQ to Tobi Send a message via Skype™ to Tobi
Originally Posted by LuckyTran View Post
fanPressure?
This will not work, as you need two patches where you apply a pressure drop. If you know the pressure at the inlet of the pump, then you can build a pressure based boundary condition couple. At the inlet you define a totalPressure and at the outlet a fixedValue. The velocity should be pressureInletVelocity and zeroGradient respectively.
daniyalaltaf likes this.
Keep foaming,
Tobias Holzmann
Tobi is offline   Reply With Quote
Old   March 28, 2019, 07:07
stefano zinna
Hi Tobias,
I only have a patch that is the exit of the vessel. At this exit I would like to apply the velocity (or flowrate) condition based on the pressure at the exit itself (or in the vessel).
Old   March 28, 2019, 07:14
Tobi's Avatar
Tobias Holzmann
Hi Stefano,
you have two options:
  • Flow Rate / Velocity based fluid motion (in simple words: you get the information of a pressure gradient)
  • Pressure based fluid motion (in simple words: you get the information of the mass flow rate)
If you know the mass flow rate, you can apply the mass flow rate at the outlet (where is the problem?). Accordingly, you use a zero pressure gradient there and a fixed on at the inlet/or a totalPressure depending on your needs and set-up.
Keep foaming,
Tobias Holzmann
Old   March 28, 2019, 07:21
stefano zinna
Hi Tobias,
This is a transient case. My flowrate / velocity should change depending on which is the pressure in the vessel.
Old   March 29, 2019, 07:48
Tobi's Avatar
Tobias Holzmann
so then you should have a pressure based force. Where is the problem?
Keep foaming,
Tobias Holzmann
Old   March 29, 2019, 07:55
stefano zinna
Hi Tobias,
How would you write such a BC for velocity and pressure?
Wind turbine simulation Saturn CFX 60 July 17, 2024 05:45
User-defined Outlet Boundary Condition in CFX modest_may CFX 5 November 27, 2017 22:08
Outlet boundary condition for compressible nozzle flows blais.bruno OpenFOAM Running, Solving & CFD 0 July 12, 2016 08:40
Error finding variable "THERMX" sunilpatil CFX 8 April 26, 2013 07:00
ATTENTION! Reliability problems in CFX 5.7 Joseph CFX 14 April 20, 2010 15:45
