running a backward-facing step with system rotation
Old   November 11, 2017, 03:56
Default running a backward-facing step with system rotation
benqing Liu
benqing is on a distinguished road
I have problem with simulation flow over backward-facing step with system rotation by OpenFoam,DNS results in literature "Turbulent flow over a backward-facing step.Part 1. Effects of anti-cyclonic system rotation". the domain in Attach Files .
I used OpenFoam with solver SRFPimpleFoam. I set intinial conditions and parameters follow tutorial Mixer but i get wrong result. So i am not sure it is proper to ues this slover and which one i should ues .
The Urel file is following:
dimensions [0 1 -1 0 0 0 0];
internalField uniform ( 0 0 0 );
boundaryField
INLET
type SRFVelocity;
inletValue uniform ( 5.6 0 0);//inlet Velocity is 5.6m/s
relative no;//not sure
value uniform ( 0 0 0 );
OUTLET
type zeroGradient;
TOP
type fixedValue;
value uniform (0 0 0 );
BOTTOM
type fixedValue;
BACKANDFRONT
type empty;
And SRFProperties file is following:
SRFModel rpm;
axis (0 0 -1);
rpmCoeffs
rpm 267.5;
From what I can see,Boundary conditions of inlet in Urel is wrong ,but i dont know which one is correct.Please help me solver this problem? I very confused...
thanks ,benqing
benqing is offline   Reply With Quote
Old   April 3, 2019, 21:42
benqing Liu
after two years ,I have not sloved the problom yet ,did anyone help me ?
now i have an another question ,which BC should i apply at the inlet ?SRFVelocity or fixedValue ?
benqing
Backward facing step. Fluids Main CFD Forum 7 December 4, 2012 11:28
Velocity drop over backward facing step warlocklw CFX 2 February 9, 2012 21:24
How to do analysis at backward facing step warlocklw CFX 5 December 21, 2011 06:50
IcoFoam parallel woes msrinath80 OpenFOAM Running, Solving & CFD 9 July 22, 2007 02:58
Backward FAcing Step - Frequency CFDtoy Main CFD Forum 8 October 29, 2006 20:51
