streamLines from a plane
Old   April 20, 2019, 08:53
Default streamLines from a plane
raf sevenants
raf sevenants is on a distinguished road
Hey,
I am simulating a wind tunnel test from a car and would like to use the streamLine function to get an idea of the streamlines over the car.
In the OpenFOAM tutorials I can only find examples where the type "uniform" is used. I would like to use the type plane but dont know how to specify the geometry of it. Can anyone help me with this?
An example of how I would want the function to look:
streamLines1
    libs            ("libfieldFunctionObjects.so");
    type            streamLine;
    writeControl    writeTime;
    setFormat       vtk;
    trackForward    true;
    fields (p U);
    lifeTime        2000;
    nSubCycle 5;
    cloudName       particleTracks;
    seedSampleSet
        type        plane;
        axis        x;
        start       (2 0 0.3); //using this start and end still results in a line of points
        end         (2 0 0.7);
        nPoints     10;
Thanks in advance
Raf
raf sevenants is offline   Reply With Quote
Plotting streamlines on a 2D plane - help with constrained steamline lightning0 STAR-CCM+ 2 December 28, 2018 18:21
[Gmsh] Problem with Gmsh nishant_hull OpenFOAM Meshing & Mesh Conversion 23 August 5, 2015 02:09
Interpreting streamlines of a rotating fan. danbence Visualization & Post-Processing 1 April 8, 2014 10:13
meaning of streamlines in plane Kiffer Main CFD Forum 0 January 7, 2013 22:14
[Gmsh] boundaries with gmshToFoam‏ ouafa OpenFOAM Meshing & Mesh Conversion 7 May 21, 2010 12:43
