[groovyBC] How to implement Inlet velocity which varies with the pressure? |
Felipe Chagas
Rep Power: 8 ![]() |
Hello guys,
I am trying to implement in openfoam a boundary condition with the groovyBC tool. I'm using interFoam to study a two-phase gas-liquid flow, where initially there was only liquid and the gas comes in after a certain period. In my problem, inlet velocity depends on the hydrostatic pressure in the inlet, which in turn varies according to the amount of gas that enters the domain. That is, the inlet velocity which the gas enters depends on the pressure, which in turn depends on the amount of gas that has already entered the domain. The equation is the following: Q=2*pi*k*H*(Pform-Pbot)/(mi*log(d1/d2)) Where pi,k,H,Pform,d1 and d2 are CONSTANT values, and Pbot is suppose to be the hydrostatic pressure in front of the inlet boundary face. My question is: How do I use the pressure field calculated by interfoam at each moment, to use in the referred equation and find the value of variable Q? Thanks in advance!! |
Felipe Chagas
Thank you all. I've got it.
zhuoyao lv
Rep Power: 0 ![]() |
I encountered the same problem as you. When setting the boundary condition of scalar C, the value of scalar B is needed, and B is updated over time. How do I get the value of B when setting the boundary condition of C?
Display Modes | |
Pressure Inlet VS velocity Inlet difference | Mohsin | FLUENT | 9 | January 4, 2021 10:34 |
outlet pressure Boundary settings -velocity streamline under ambient temp.conditions | Vishnu_bharathi | CFX | 12 | November 21, 2017 06:56 |
UDF to set velocity and pressure in inlet | GerardX89 | Fluent UDF and Scheme Programming | 0 | July 16, 2012 10:15 |
Set inlet velocity and pressure in cavitational model | GerardX89 | FLUENT | 1 | July 5, 2012 16:17 |
Neumann pressure BC and velocity field | Antech | Main CFD Forum | 0 | April 25, 2006 02:15 |
