Unable to read all cell centers in OF v2.4
In my user-defined energy source file, I am trying to read the cellCenters of the mesh using the command "const vectorField& C = mesh_.C().internalField();" As next step I want to check if the cell center is in particular location. If yes I will introduce energy source into that cell. But for some reason that command does not function properly. It gives only 490 cell center points when I have 6174 points. It would of great help for me if you can identify the issue. Thank you. sourceRegionNew.clear(); sourceRegionNew.set(new cellSet(mesh(), "sourceRegionRefine", IOobject::NO_READ, IOobject::AUTO_WRITE)); scalar cur_time = mesh().time().value(); if (cur_time <= 5e-8) { const scalarField& V = mesh_.V(); //const vectorField& C = mesh_.C().internalField(); const volVectorField& C = mesh_.C(); scalarField& hSource = eqn.source(); scalar len = 0.00025; scalar W_pm = 1.0*s_efficiency; scalar power = W_pm*len; scalarList power_actual(1, 0.0); scalarList total_volume(1, 0.0); scalarList x_max(1, 0.0); scalar E = 0.000017; scalar L_s = 0.0005; scalar r_0 = 0.00005; scalar r_02 = r_0 * r_0; scalar preExpConst = E/L_s/r_02/M_PI; forAll(C, i) { vector s_off = C[i]; scalar x = s_off.x(); Info << PV(s_off) << endl; if ((x > 0.0003) && (x < 0)) { Info << "offset X " << endl; vector s_off1 = C[i] - s_origin; scalar r2 = s_off1.x()*s_off1.x() + s_off1.y()*s_off1.y() + s_off1.z()*s_off1.z(); sourceRegionNew().set(i); Info << "3 directions checked and source found" << endl; scalar cellPow = W_pm*V[i]*preExpConst*exp(-1*pow((sqrt(r2)/r_0),8))/cur_time; Info << "calculating cellPow and preExpConst " << PV(cellPow) << PV(preExpConst) << endl; hSource[i] -= cellPow; power_actual[0] += cellPow; total_volume[0] += V[i]; if (s_off.x() > x_max[0]) x_max[0] = s_off.x(); } } } |
