problem with includeFunc residuals
Old   September 24, 2019, 00:41
Unhappy problem with includeFunc residuals
Srikar
srikarg is on a distinguished road
I am using openfoam v5 and i was trying put the code:
functions
{ #includeFunc residuals} in the controldict file. i get the error:
--> FOAM FATAL ERROR:
[2]
request for objectRegistry region0 from objectRegistry single_channelprocessor2 failed
available objects of type objectRegistry are
2
fluid
sink
Can anyone tell me what to do?:
srikarg is offline   Reply With Quote
Old   September 24, 2019, 04:38
anonymous
simrego is on a distinguished road
Hi!
I assume you are using some multi region solver like chtMultiRegionFoam.
In this case you have to define the region name for the residuals function.
(I think you have a file called residuals in your system dir. Then just add a line: "region fluid", or sink if you need that one. Maybe it is regionName, I'm not sure 100%. Hard to follow any changes/versions )
simrego is offline   Reply With Quote
Old   September 24, 2019, 05:16
Talking Could you elaborate?
Srikar
Originally Posted by simrego View Post
Hi!
Yes. fluid and sink here are region names. Could you elaborate where to add the lines?
chtmultiregionsimplefoam, openfoam, openfoam v5, residuals
Ho to justify that the problem is stiff in numerical study ALBATTROSS Main CFD Forum 0 July 11, 2019 17:08
Problem with energy residuals amin.z FLUENT 0 September 24, 2014 08:15
Problem with residuals, especially continuity Ozgur_ FLUENT 2 December 3, 2013 05:48
judging convergence through residuals MachZero Main CFD Forum 7 December 25, 2012 12:18
Convergence - scaled vs unscaled residuals HS FLUENT 1 November 7, 2005 05:45
