problem with includeFunc residuals
I am using openfoam v5 and i was trying put the code: functions { #includeFunc residuals} in the controldict file. i get the error: --> FOAM FATAL ERROR: [2] request for objectRegistry region0 from objectRegistry single_channelprocessor2 failed available objects of type objectRegistry are 2 ( fluid sink ) Can anyone tell me what to do?: |
Hi!
I assume you are using some multi region solver like chtMultiRegionFoam. In this case you have to define the region name for the residuals function. (I think you have a file called residuals in your system dir. Then just add a line: "region fluid", or sink if you need that one. Maybe it is regionName, I'm not sure 100%. Hard to follow any changes/versions :D) |
Could you elaborate?
