mappedVelocityFlux boundary condition correct implementation |
December 29, 2019, 10:10 |
Armin Alavi
Rep Power: 6 |
hi all
I have been trying to use the mappedVelocityFlux B.C. to map the velocity from the neighbour mesh to the boundary which this condition is applied on. when i use the bellow format (exactly like what said on https://cpp.openfoam.org/v3/a01417.html melt_to_solid { type mappedVelocityFlux; phi phi; value uniform 0; } i get the following error: --> FOAM FATAL IO ERROR: Expected a '(' while reading VectorSpace<Form, Cmpt, Ncmpts>, found on line 43 the label 0 file: /home/armin/OpenFOAM/armin-6/run/Mytut/conjugateStoragezzCompressiblePorous/0/melt/U.boundaryField.melt_to_solid.value at line 43. From function Foam::Istream& Foam::Istream::readBegin(const char*) in file db/IOstreams/IOstreams/Istream.C at line 92. FOAM exiting I sense the above error is trying to tell me that i have to implement the "value" in vector type so i change my B.C. to the bellow form: melt_to_solid { type mappedVelocityFlux; phi phi; value uniform (0 0 0); } but this time a rather stranger error shows up: --> FOAM FATAL ERROR: hanging pointer at index 4 (size 4), cannot dereference From function T& Foam::UPtrList<T>:: operator[](Foam::label) [with T = Foam::fvsPatchField<double>; Foam::label = int] in file /home/ubuntu/OpenFOAM/OpenFOAM-6/src/OpenFOAM/lnInclude/UPtrListI.H at line 123. FOAM aborting #0 Foam::error:: printStack(Foam::Ostream&) at ??:? #1 Foam::error::abort() at ??:? #2 Foam::mappedVelocityFluxFixedValueFvPatchField::up dateCoeffs() at ??:? #3 Foam::fvMatrix<Foam::Vector<double> >::fvMatrix(Foam::GeometricField<Foam::Vector<doub le>, Foam::fvPatchField, Foam::volMesh> const&, Foam::dimensionSet const&) in "/home/armin/OpenFOAM/armin-6/platforms/linux64GccDPInt32Opt/bin/chtMultiPorousCompInterFoam" #4 ? in "/home/armin/OpenFOAM/armin-6/platforms/linux64GccDPInt32Opt/bin/chtMultiPorousCompInterFoam" #5 ? in "/home/armin/OpenFOAM/armin-6/platforms/linux64GccDPInt32Opt/bin/chtMultiPorousCompInterFoam" #6 __libc_start_main in "/lib/x86_64-linux-gnu/libc.so.6" #7 ? in "/home/armin/OpenFOAM/armin-6/platforms/linux64GccDPInt32Opt/bin/chtMultiPorousCompInterFoam" Aborted (core dumped) Anyone has a clue what should I do? I would appreciate any guidance |
December 29, 2019, 16:21 |
Herpes Free Engineer
Rep Power: 12 |
I dont know about OF6, but are you sure that v3 syntax remained the same in v6, which seems to be you are using.
The OpenFOAM community is the biggest contributor to OpenFOAM: User guide/Wiki-1/Wiki-2/Code guide/Code Wiki/Journal Nilsson/Guerrero/Holzinger/Holzmann/Nagy/Santos/Nozaki/Jasak/Primer Governance Bugs/Features: OpenFOAM (ESI-OpenCFD-Trademark) Bugs/Features: FOAM-Extend (Wikki-FSB) Bugs: OpenFOAM.org How to create a MWE New: Forkable OpenFOAM mirror |
December 30, 2019, 13:55 |
Armin Alavi
Rep Power: 6 |
Thank you very much for your response. I checked the source code for OF6. it seems that it's syntax has remained unchanged since then.
here is the source code https://github.com/OpenFOAM/OpenFOAM...FvPatchField.H |
December 30, 2019, 17:24 |
Rep Power: 12 |
Please look at .C file, which had several changes. Also, the correct syntax is for 'value' placeholder is 'value uniform 0;' Could you please check semi-columns/header file above-below of this part of the input?
Error - Solar absorber - Solar Thermal Radiation | MichaelK | CFX | 12 | September 1, 2016 05:15 |
several fields modified by single boundary condition | schröder | OpenFOAM Programming & Development | 3 | April 21, 2015 05:09 |
Low Mixing time Problem | Mavier | CFX | 5 | April 29, 2013 00:00 |
vorticity boundary condition | bearcharge | Main CFD Forum | 0 | May 14, 2010 11:32 |
RPM in Wind Turbine | Pankaj | CFX | 9 | November 23, 2009 04:05 |
