Initialize internal field as Atmospheric BL profile given in the inlet
Old   June 19, 2019, 10:51
Default Initialize internal field as Atmospheric BL profile given in the inlet
Hüseyin Can Önel
hconel is on a distinguished road
Hi all,
In my simulation, I apply the
atmBoundaryLayerInletVelocity
type BC at inlet, and I also would like to initialize the whole flow field (internal cells) as whatever profile is calculated at the inlet boundary with atmBoundaryLayerInletVelocity, instead of a uniform velocity. This is a profile that varies in the z (upward) direction only.
Is this possible in OpenFOAM?
Thanks in advance.
hconel is offline   Reply With Quote
Old   June 20, 2019, 04:58
Tom Fahner
tomf will become famous soon enoughtomf will become famous soon enough
Send a message via MSN to tomf Send a message via Skype™ to tomf
I would say this is possible, probably by using the codestream functionality, or using funkySetFields from swak4Foam. I do not have an example ready, but if you search the forum a bit, you may find one.
Regards,
Tom
tomf is offline   Reply With Quote
Old   February 10, 2020, 06:27
HPE
HPE's Avatar
Herpes Free Engineer
HPE is on a distinguished road
FYI: OFv1912 has recently learned `setExprBoundaryFields` and `setExprFields` which are the OpenFOAM implementations of the various functionalities of the famous `swak4Foam`.
HPE is offline   Reply With Quote
How to generate Time varying Inlet velocity with a particular profile faiazk OpenFOAM Pre-Processing 15 June 3, 2021 06:16
[Other] dynamicTopoFVMesh and pointDisplacement RandomUser OpenFOAM Meshing & Mesh Conversion 6 April 26, 2018 07:30
UDF inlet velocity profile mismatch with Fluent ChristineL Fluent UDF and Scheme Programming 15 November 25, 2016 06:45
field function and tables for inlet profile natalie26 STAR-CCM+ 3 March 5, 2013 02:54
Neumann pressure BC and velocity field Antech Main CFD Forum 0 April 25, 2006 02:15
