February 10, 2020, 03:10 |
Reynolds Number of a non-uniform duct
Raza Javed
Rep Power: 7 |
Hello Everyone,
I have a question relating to the calculation of the Reynold number. If I have a non-uniform duct or may be a pipe, and at the inlet of the pipe, the cross-section area will be different, and as the length of the pipe increases, the area and the shape of the pipe changes. Now, in this case if I want to calculate the Reynolds number to check whether my flow will be laminar or Turbulent. Do I need to just consider the area of the pipe at the inlet and calculate the Reynolds number or is there any other way to calculate it in this case? Thank you for your help. Raza |
February 10, 2020, 23:19 |
Glenn Carlson, PE, PhD (ret)
Rep Power: 13 |
Hi, Raza.
The critical Reynolds number dividing laminar and turbulent flow regimes was found from experiments with long round pipes. Flow in non-uniform ducts may show recirculation, separation, or other phenomena that don't arise for long straight pipe. Therefore, the well-known Re.crit = 2000 should not be assumed correct for other shaped pipe. If a non uniform pipe has a long straight section, it begins to make sense to apply a Reynolds numbee in that section. But, otherwise, IMO, the Reynolds number is not particularly useful for non-uniform pipes. Regards, Glenn Last edited by gcengineer; February 11, 2020 at 00:43. |
February 11, 2020, 03:05 |
#3 | |
Raza Javed
Rep Power: 7 |
Hi Glenn, Thank you so much for your reply. As I am modelling the air Flow, in this case, if I want to check whether the flow will be laminar OR Turbulent, what could be the possible approach to do that? Thank you. |
laminar, reynolds number, turbulence |
[snappyHexMesh] Error snappyhexmesh - Multiple outside loops | avinashjagdale | OpenFOAM Meshing & Mesh Conversion | 53 | March 8, 2019 09:42 |
Too high omega and k values in vortex flow simulation | thomas. | OpenFOAM Running, Solving & CFD | 9 | March 30, 2016 06:45 |
OpenFOAM solution is diverging for stress analysis in two-pahse microstructure. | Sargam05 | OpenFOAM | 16 | April 30, 2013 16:18 |
[swak4Foam] Air Conditioned room groovyBC | Sebaj | OpenFOAM Community Contributions | 7 | October 31, 2012 14:16 |
Need help with boundary conditions: open to atmosphere | Wolle | OpenFOAM | 2 | April 11, 2011 07:32 |
