March 25, 2022, 06:47 |
Set a face as the inlet
Haroun
Rep Power: 4 |
Hi everyone,
So I am new to OpenFOAM and I have this simple system composed of two injectors (water and air) and a mixing room. I have in total 6 .stl files which are described by their names : 'INLET_AIR' 'INLET_WATER' 'WALL_AIR' 'WALL_WATER' 'OUTLET' 'PLENUM' I've just done the meshing part and everything seems to be OK. Now, I only want to set the surface of 'INLET_WATER' as the inlet surface but I absolutely have no idea of how to proceed since in every tutorial I did they define the inlet and outlet as faces of the bloc generated from blockMesh. What is the procedure to set a face of the geometry as the inlet and not a face of the bloc ? |
[surface handling] Decomposing Faces after Extrude2DMesh with autoPatch | JEBland | OpenFOAM Meshing & Mesh Conversion | 5 | December 6, 2021 07:28 |
Seakeeping Solver:Crashed | akbarbagusd | Fidelity CFD | 0 | November 5, 2021 12:42 |
[blockMesh] Errors during blockMesh meshing | Madeleine P. Vincent | OpenFOAM Meshing & Mesh Conversion | 51 | May 30, 2016 10:51 |
[snappyHexMesh] determining displacement for added points | CFDnewbie147 | OpenFOAM Meshing & Mesh Conversion | 1 | October 22, 2013 09:53 |
[Gmsh] Import problem | ARC | OpenFOAM Meshing & Mesh Conversion | 0 | February 27, 2010 10:56 |
