mixed boundary condition
Dear all,
I have a probably newbie question but i can find the answer by myself I want to implement convective heat transfer using mixed type BC. After checking on the web i found that it could be somethink like that: Code:
So my question is simple (and probably stupid), how to pass an expression in openfoam, (for example fixedValue 273.15+25 instead of 298.15) Thank you very much for help Yann |
Dear Yann
you can use groovyBC. check the openfoamwiki and find more information and the capabilities of groovyBC. |
Dear Paymen
I use openfoam7 and it seems that groovyBC is not an option anymore In the other hand, i tried codedMixed BC typr as the following Code:
top |
What solver do you use? What is 0.6 (thermal conductivity? thermal diffusivity? just a random number?)? |
hello,
I am using buoyantPimpleFoam, and the parameter corresponds to water thermal conductivity, I just don't know how to get it properly from thermophysical properties, (If you know I will be glad to know too :) ) I also realize that I made a mistake, according to this well made document: https://foamingtime2.files.wordpress...ction-bc_1.pdf It should be Code:
Or
this->valueFraction() = 1.0/(1+0.6*delta); |
Sorry i am newbie, I don't really understand how to lookup variables like in the example
Since the example is general, it has lots of checks, you can get rid of them for your concrete situation. You have mentioned water, so I assume, you use fluidThermo, so the code for kappa lookup is:
typedef compressible::turbulenceModel turbulenceModel; In BC you can access mesh object like this, for example: Code:
const fvMesh& mesh = patch_.boundaryMesh().mesh(); |
I think i miss something (sorry, i am really bad at c++)
code |
I do not think you have basicThermo in coded BC. You should use codeInclude section to add necessary includes. Something like:
codeInclude |
It is asking me a system/codeDict, I never have seen file like this so far.
It would be easier to figure out a cause of the problem if you post solver/compiler output. "Guess-what-is-wrong" game can take quite a long time.
Sure
--> FOAM FATAL ERROR: |
Could you post final version of the BC? It seems, you have lost semi-colon, since:
A special form is if the 'code' section is not supplied. In this case |
Here you go
FoamFile |
Semicolon is missing after codeInclude entry (so code entry is eaten by codeInclude). It should be:
top |
Of course, thank you so much
PS: j'espere que tout va bien pour toi dans l'est |
after adding the semicolon, I have another error:
Using dynamicCode for patch top on field T at line 26 in "/home/yann/Projet/0/T.boundaryField.top" |
The warning is self-explanatory, you do not need ; after #include "fluidThermo.H".
The error is due to missing -I flags. You need to add codeOptions section, there you put -I$(LIB_SRC)/thermophysicalModels/basic/lnInclude: Code:
codeOptions |
Using dynamicCode for patch top on field T at line 26 in "/home/yann/Projet/0/T.boundaryField.top" Still not working |
