May 5, 2020, 09:35 |
how to map inlet profile to internal fields
Neilson Whit
Dear Foamers,
Is it possible to map the inlet profile of any field to the internal field? For example I want to have same profile in the internal mesh regions with the inlet patch. How can be done? is there any tutorial? thanks |
May 29, 2020, 03:52 |
Rep Power: 8 |
do i understand correctly that you don't want that your flow change within your domain? so lets say you give an inlet flow distribution and your flow doesn't change within a pipe or so?
May 29, 2020, 07:18 |
#3 | |
Neilson Whit
No It will change. inlet profile will be an initial condition for internal field, i.e, internalField |
May 29, 2020, 18:29 |
Herpes Free Engineer
Rep Power: 12 |
There is no direct utility to perform this, but you can use a coded function object or other coded utilities. On the other hand, if you would like to map velocity - you would need to map it as a body force, and/or into the pressure-velocity coupling algorithm (it is doable, and has been done extensively, e.g. actuator line modelling or Kim et al. 2013's synthetic turbulent inlet flow mapping for LES simulations etc) I'm extremely tired, so can't elaborate further, but can you give more details on what you want to accomplish? what type of field you would like to map (e.g. temperature? velocity?), or for compressible/incompressible flows etc?
The OpenFOAM community is the biggest contributor to OpenFOAM: User guide/Wiki-1/Wiki-2/Code guide/Code Wiki/Journal Nilsson/Guerrero/Holzinger/Holzmann/Nagy/Santos/Nozaki/Jasak/Primer Governance Bugs/Features: OpenFOAM (ESI-OpenCFD-Trademark) Bugs/Features: FOAM-Extend (Wikki-FSB) Bugs: OpenFOAM.org How to create a MWE New: Forkable OpenFOAM mirror |
May 29, 2020, 19:07 |
Neilson Whit
Thank you very much HPE.
I want to map U, k, omega, and T. Solver is chtMultiRegionFoam. Compressible solver. |
May 31, 2020, 15:28 |
Rep Power: 12 |
- I think you may need to modify the relevant codes, I'm afraid. There is no off-the-shelf utility for doing such task, afaik. - Would you please let us know if there is such a utility comes your way?
inlet, internalfields, mapfield |
Map fields to a parallel target in OF 2.4.0 | DominicTNC | OpenFOAM Running, Solving & CFD | 3 | November 2, 2017 18:32 |
extracting outlet velocity profile from one case to another case's inlet | tonggysun | OpenFOAM | 2 | September 13, 2013 04:19 |
How to apply an outlet velocity profile to another inlet? | siw | FLUENT | 4 | April 10, 2013 11:19 |
How to prescribe fully developed turbulent velocity profile at inlet? | nore5 | OpenFOAM Running, Solving & CFD | 1 | February 22, 2013 09:30 |
Create hemisphere like velocity profile at inlet | Nelson | Main CFD Forum | 3 | July 27, 2005 12:05 |
