Strange issue with OF v1906 and pointDisplacement
Old   May 8, 2020, 23:42
Default Strange issue with OF v1906 and pointDisplacement
TWB
quarkz is on a distinguished road
I tried to run decomposePar and renumberMesh (parallel) before running the simulation as usual in OF v1906
However, when I run 'mpirun pimpleFoam -parallel', I got the error:
[3] --> FOAM FATAL IO ERROR:
[3] [0]
Essential entry 'value' missing
[3]
[3] file: /scratch/users/nus/tsltaywb/OpenFOAM/naca0012_naca0008_200x51_test_err/processor3/0/pointDisplacement.boundaryField.flap_wall
[3]
[3] From function Foam::valuePointPatchField<Type>::valuePointPatchF ield(const Foam:ointPatch&, const Foam:imensionedField<Type, Foam:ointMesh>&, const Foam::dictionary&, bool) [with Type = Foam::Vector<double>]
[3] in file /home/project/11000324/OpenFOAM/OpenFOAM-v1906/src/OpenFOAM/lnInclude/valuePointPatchField.C at line [0]
On inspection, I found that the entry:
value uniform (0 0 0);
is removed in pointDisplacement
The orginal pointDisplacement is:
boundaryField
flap_wall
type angularOscillatingDisplacement;
axis (0 0 1);
origin (1.02 0.0 0.02);
angle0 0;
amplitude 0.358; //units of rad
omega 6.28; //units of rad/s
I found that either running decomposePar or renumberMesh will remove the value statement, preventing pimpleFoam from working.
Even running in serial with renumberMesh will give the error. v1812 seems to be working though.
Does anyone has the same experience?
Thanks.
quarkz is offline   Reply With Quote
Old   May 9, 2020, 06:13
HPE
HPE's Avatar
Herpes Free Engineer
HPE is on a distinguished road
Is there any tutorial you can provide or indicate that we can try to reproduce the error?
Thanks
HPE is offline   Reply With Quote
Old   September 16, 2020, 03:56
TWB
Sorry for the delay. I have shared a link to the error case. It is a naca0012 airfoil with a naca008 flap behind. The flap is supposed to rotate.
Error appears with v1906.
https://app.box.com/s/s968xxa6pyfum8esjjs50ttfpr3h7a7o
I tested v2006 and it seems to have been resolved.
Old   October 24, 2020, 05:32
Ali
AliVali is on a distinguished road
Hi quarkz.
I have a similar problem. I can run the model with single cpu but get the following error and using decomposerPar.
Time = 0
Selecting solid-body motion function tabulated6DoFMotion
Processor 0: field transfer
keyword solidBodyMotionFunction is undefined in dictionary "/mnt/e/DHI/Work/surfLake/New_CFD/floatingObject/test_rigidBody/0/pointDisplacement.boundaryField.floatingObject.tab ulated6DoFMotionCoeffs"
file: /mnt/e/DHI/Work/surfLake/New_CFD/floatingObject/test_rigidBody/0/pointDisplacement.boundaryField.floatingObject.tab ulated6DoFMotionCoeffs from line 43 to line 45.
From function const Foam::entry& Foam::dictionary::lookupEntry(const Foam::word&, bool, bool) const
in file db/dictionary/dictionary.C at line 573.
FOAM exiting
floatingObject
type solidBodyMotionDisplacement;
solidBodyMotionFunction tabulated6DoFMotion;
tabulated6DoFMotionCoeffs
CofG (0.5 0.5 0.5);
// timeDataFileName "<constant>/6DoF.dat";
timeDataFileName "$FOAM_CASE/constant/6DoF.dat";
and dynamicMeshDict is as follows
FoamFile
version 2.0;
format ascii;
class dictionary;
object dynamicMeshDict;
dynamicFvMesh dynamicMotionSolverFvMesh;
motionSolverLibs (fvMotionSolvers);
solver displacementLaplacian;
displacementLaplacianCoeffs
diffusivity inverseDistance (floatingObject);
// diffusivity quadratic inverseDistance (floatingObject);
I checked with of2006 and openFOAm7, get the similar error.
Any help would be highly appreciated.
Ali
AliVali is offline   Reply With Quote
Old   September 16, 2021, 18:26
William Lambert
wblambert is on a distinguished road
Hi AliVali,
I am getting this exact error. Did you find a solution to this problem?
Thanks
wblambert is offline   Reply With Quote
Old   June 29, 2022, 09:08
Cristóbal
cibanez is on a distinguished road
I'm also getting the same error as AliVali, but with oscillatingRotatingMotion instead. Does anyone know the cause or have a fix for it?
/Cristóbal
cibanez is offline   Reply With Quote
Old   June 29, 2022, 12:17
TWB
Hi all, I suggest getting an example from the tutorials which is similar to your problem. Make sure it's working 1st. Then replace it with your mesh and some other impt parameters step by step. Testing along the way. Somehow I think it worked for me.
Old   June 30, 2022, 10:04
Cristóbal
I was able to decompose that pointDisplacement field. As said before the case was running in serial but I could not get it to decompose.
The following boundary condition for pointDisplacement runs in serial but does not decompose the field:
wing
        solidBodyMotionFunction oscillatingRotatingMotion;
        oscillatingRotatingMotionCoeffs
           origin      (0 0.1 0);
           axis        (1 0 0);
           omega       50;          // rad/s, 1rad/s=9.5rpm
           amplitude   (0.15 0 0);    // max amplitude (degrees)
The fix for it is to include solidBodyMotionFunction oscillatingRotatingMotion inside oscillatingRotatingMotionCoeffs, which is a rather strange way of writting the coefficients.
wing
           origin      (0 0.1 0);
           axis        (1 0 0);
I think this might be a bug as the same error can be replicated in the tutorial case "box2D_moveDynamicMesh" when trying to decompose it.
/C
Old   July 14, 2022, 11:38
Default Bug reported and fixed
Cristóbal
This bug has been reported and recently closed.
Here you can find the closed ticket. https://develop.openfoam.com/Develop.../-/issues/2526
And here you can find the commit with the changes made to Foam::solidBodyMotionFunction::solidBodyMotionFunc tion https://develop.openfoam.com/Develop...bd61c1c1d93c65
/C
Old   August 12, 2022, 02:28
Ali
Originally Posted by wblambert View Post
Hi AliVali,
Thanks
Hi William,
No I couldn't solve it. Unfortunately in OF2112 also fails. My workaround is to decompose it using OF/8, then run it with OF/2006. I know this is a silly solution, but it works most the times. It sounds there is solution at
I haven't checked it, yet
