Add active scalar equation to chtMultiRegionFoam
Old   May 10, 2020, 08:05
Default Add active scalar equation to chtMultiRegionFoam
Mike Jäger
mikejaeger is on a distinguished road
Hi OpenFOAMers,
I have a multiRegion case (different types of solids, no fluid). Within some solid regions I want to add a heat source which is changing with time. I can do this with fvOptions (swak4foam), but this heat source depends on another parameter (an active scalar equation). The extra equation which must be added to the solver is the load X:
dX/dt = K * (X - X_eq(T))
K is constant. Behind X_eq is an analytical equation depending on the temperature field of the solid.
The heat source looks like this:
S = C * dX/dt * dH(X)
C is constant and the source depends on dX/dt and X. Is it possible to add such "active" equation for X via swak4foam as well? I searched a lot and didn't came to a succesful result.
Or is there no way around to program a custom solver with chtMultiRegionFoam as the base (I am beginner in C++ )?
mikejaeger is offline   Reply With Quote
whats the cause of error? immortality OpenFOAM Running, Solving & CFD 13 March 24, 2021 07:15
Issue symmetryPlane 2.5d extruded airfoil simulation 281419 OpenFOAM Running, Solving & CFD 5 November 28, 2015 13:09
Question about openFOAM installation on Mac MohandeseIrani OpenFOAM Installation 14 October 28, 2014 09:28
error message cuteapathy CFX 14 March 20, 2012 06:45
Scalar Equation source term Merck CFX 0 May 11, 2007 05:30
