line plot
Old   June 18, 2020, 19:59
Default line plot
Typ
Typ is on a distinguished road
do you know where this error come from:
--> FOAM Warning :
    From function void Foam::particle::locate(const vector&, const vector*, Foam::label, bool, const Foam::string&)
    in file particle/particle.C at line 483
    Particle initialised with a location outside of the mesh when tracking from centre (-2.91666667 0.025 0.0208333333) of cell 0 to position (-2.91 0.025 0)
--> FOAM Warning :
    Particle initialised with a location outside of the mesh when tracking from centre (-1.91666667 0.025 0.0208333333) of cell 6 to position (-1.91 0.025 0)
--> FOAM Warning :
    Particle initialised with a location outside of the mesh when tracking from centre (-1.04166667 0.0125 0.0104166667) of cell 463 to position (-1.04 0.0125 0)
Reading set description:
    wire1
    wire2
    wire3
    wire4
    wire5
and how i can avoid it? Besides does this influence my results in measuring?
Typ is offline   Reply With Quote
problem during mpi in server: expected Scalar, found on line 0 the word 'nan' muth OpenFOAM Running, Solving & CFD 3 August 27, 2018 04:18
[Gmsh] No cells read from file ".msh" hwsv07 OpenFOAM Meshing & Mesh Conversion 5 August 13, 2018 15:42
8x icoFoam speed up with Cufflink CUDA solver library kmooney OpenFOAM Running, Solving & CFD 42 November 6, 2012 11:37
Installation OF1.5-dev ttdtud OpenFOAM Installation 46 May 5, 2009 02:32
[blockMesh] BlockMeshmergePatchPairs polyTopoChanger benru OpenFOAM Meshing & Mesh Conversion 3 June 29, 2008 21:24
