cfMesh installation: OpenFOAM 4.x Ubuntu 18.04 |
February 22, 2019, 10:56 |
Rep Power: 7 |
Hello all,
I am facing a problem during cfMesh installation on ubuntu 18.04. The error is as given below. I have also attached a detailed log file with this. Could you please help me? lnInclude/DynListI.H: In instantiation of ‘Foam:ynList<T, staticSize>:ynList(const ListType&) [with ListType = int; T = Foam::Vector2D<double>; long int staticSize = 6]’: lnInclude/helperFunctionsGeometryQueriesI.H:1221:37: required from here lnInclude/DynListI.H:195:15: error: request for member ‘size’ in ‘l’, which is of non-class type ‘const int’ setSize(l.size()); ~~^~~~ lnInclude/DynListI.H:197:32: error: subscripted value is neither array nor pointer this->operator[](i) = l[i]; ~^ make: *** [Make/linux64GccDPInt64Opt/utilities/meshes/polyMeshGenModifier/polyMeshGenModifierAddBufferCells.o] Error 1 Making dependency list for source file cartesian2DMesh.C could not open file foamTime.H for source file cartesian2DMesh.C due to No such file or directory /usr/bin/ld: cannot find -lmeshLibrary collect2: error: ld returned 1 exit status make[1]: *** [/home/hrushi/OpenFOAM/hrushi-4.x/platforms/linux64GccDPInt64Opt/bin/cartesian2DMesh] Error 1 make: *** [cartesian2DMesh] Error 2 Making dependency list for source file FLMAToSurface.C /usr/bin/ld: cannot find -lmeshLibrary collect2: error: ld returned 1 exit status make[1]: *** [/home/hrushi/OpenFOAM/hrushi-4.x/platforms/linux64GccDPInt64Opt/bin/FLMAToSurface] Error 1 make: *** [FLMAToSurface] Error 2 |
May 23, 2019, 09:23 |
Chris Warrender
Hello Scientium,
I am having the same problem as yourself with trying to run ./Allwmake for cfMesh 1.1.2 with OF4.x on Ubuntu 18.04. Did you manage to find a way to compile cfMesh fully? Also find attached my log.make for info. Thanks Chris Last edited by Chr1st0ph3r93; May 24, 2019 at 07:03. Reason: Added log file |
August 6, 2020, 20:37 |
Utkun Malkocoglu
Rep Power: 9 |
I know that there is nothing new since last year, but I hope that maybe you have solved your problem even though you did not write here. Were you able to solve this problem? If so, how did you manage to?
Thanks in advance. Last edited by Malkocoglu; August 7, 2020 at 08:12. |
Map of the OpenFOAM Forum - Understanding where to post your questions! | wyldckat | OpenFOAM | 10 | September 2, 2021 05:29 |
how do i fix installation error of ansys 19.0 on ubuntu 18.04 | rid_taki | ANSYS | 15 | June 7, 2021 06:32 |
[OpenFOAM.org] icoFoam: Command not found in OpenFOAM 3.0.1 installation on Ubuntu 16.10 | febriyan91 | OpenFOAM Installation | 2 | July 27, 2020 00:23 |
[OpenFOAM.org] OpenFoam 3.0 installation on Ubuntu 14.04.3 | tab2001ng | OpenFOAM Installation | 3 | March 8, 2016 01:38 |
openFOAM installation in ubuntu 11.10 | kirubhakaran | OpenFOAM Installation | 5 | February 17, 2012 02:16 |
