incorrect results from wallHeatFlux utility
Old   June 28, 2020, 08:15
Default incorrect results from wallHeatFlux utility
CFDUSER
tbhanderi is on a distinguished road
I am using wallHeatFlux utility to calculate heat flux on wall patches. But when I run the post processing function it calculates heat flux based on the temperature and intital values provided in 0 folder. And copying same values of flux in rest of the solution time steps, however the temperature profile is changing during simulation.
Does anyone know why this post processing function does not calculate heatflux based on temperature field of every time step ?? OR am i missing something ??
command : buoyantSimpleFoam -postProcess -func wallHeatFlux
I have added wallheatflux dictionary file in system folder as given below:
\\ / F ield | OpenFOAM: The Open Source CFD Toolbox
\\ / O peration | Version: v1912
\\ / A nd | Website: www.openfoam.com
\\/ M anipulation |
Description
Calculates the heat-flux at wall patches, outputting the data as a
volScalarField.
type wallHeatFlux;
libs ("libfieldFunctionObjects.so");
executeControl writeTime;
writeControl writeTime;
calculated wallHeatFlux values provided in attachment.
tbhanderi is offline   Reply With Quote
Old   June 28, 2020, 10:46
HPE
HPE's Avatar
Herpes Free Engineer
HPE is on a distinguished road
Do you want to compute `wallHeatFlux` during runtime or as postprocessing operation?
The `postProcess` utility is going to execute `wallHeatFlux` function object on the available solutions based on the settings file you have attached.
HPE is offline   Reply With Quote
Old   June 28, 2020, 12:04
CFDUSER
Thank you for your reply.
Yes. I want to calculate "wallHeatFlux" as postprocessing operation.
But as per attached result file, It gives same flux values in all iterations (0 to 1221), However it shouldn't be the same value.
Just to check it's dependance on changing scalarFields(e.g. temperature) over the iterations, I've once deleted the results and tried calculating the "wallHeatFlux" and it gave me the same value.
So wallHeatflux calculation is independant of intermediate time steps results, it only depends on value assigned in 0 folder and that makes no sense. could you please tell me what might be the problem ?
Also please tell me how to calculate it runtime ?
buoyantBoussinesqPimpleFoam gives incorrect results for non-steady laminar flows Simba OpenFOAM Running, Solving & CFD 5 November 24, 2020 04:46
wrong calculation of wallHeatFlux utility in solid patches zfaraday OpenFOAM Post-Processing 6 January 12, 2016 16:39
wallHeatFlux utility with sonicFoam hiuluom OpenFOAM Post-Processing 3 September 18, 2015 07:39
[waves2Foam] Does the surfaceElevation utility give correct results for parallel case? ashim OpenFOAM Community Contributions 1 July 22, 2015 09:24
LES of highly heated pipe flow - incorrect results MichalH FLUENT 3 June 3, 2009 05:00
