June 29, 2020, 06:49 |
faceProcAddressing file missing in polyMesh
Hi everyone!
I would need your help in order to understand how to create the file "faceProcAddressing" in the polyMesh folder inside the processors folder. I am running a LES simulation in parallel with OpenFoam v1606. I decomposed the case and I solved it with pimpleFoam. The computation is completed but when I open the following path for a generic processor: processor*/constant/polyMesh/ , the faceProcAddressing, boundaryProcAddressing, cellProcAddressing, pointProcAddressing file are missing. I would need these file because I am trying to use another software to read the OpenFoam results as input, and it requires these file in the polyMesh folder in order to read the data. Does somebody know how to create these type of file? Maybe it regards some setting in the decomposeParDict or in the renumberMesh? Thanks for your help! |
decomposed mesh, faceprocaddressing, polymesh, pre processing, renumbermesh |
Custom Thermophysical Properties | wsmith02 | OpenFOAM | 4 | June 1, 2023 14:30 |
Using PengRobinsonGas EoS with sprayFoam | Jabo | OpenFOAM Running, Solving & CFD | 35 | April 29, 2022 15:35 |
[swak4Foam] funkyDoCalc with OF2.3 massflow | NiFl | OpenFOAM Community Contributions | 14 | November 25, 2020 03:30 |
[OpenFOAM] Annoying issue of automatic "Rescale to Data Range " with paraFoam/paraview 3.12 | keepfit | ParaView | 60 | September 18, 2013 03:23 |
