funkySetFields
Old   September 28, 2020, 00:00
Default funkySetFields
Josh McCraney
joshmccraney is on a distinguished road
Hi All!
I am running OpenFOAM 6. When executing funkySetFields -time 0 I get the error:
  \\      /  F ield         | OpenFOAM: The Open Source CFD Toolbox
   \\    /   O peration     | Website:  https://openfoam.org
    \\  /    A nd           | Version:  6
     \\/     M anipulation  |
Build  : 6-fa1285188035
Exec   : funkySetFields -time 0
Date   : Sep 27 2020
Time   : 23:57:05
Host   : "josh-Super-Server"
PID    : 833
I/O    : uncollated
Case   : /home/josh/OpenFOAM/josh-6/run/cases/ICF4/tank_2/case
nProcs : 1
fileModificationChecking : Monitoring run-time modified files using timeStampMaster (fileModificationSkew 10)
allowSystemOperations : Allowing user-supplied system call operations
swakVersion: 0.4.3 (Release date: Next release)
Create time
Create mesh for time = 0
Time = 0
 Using funkySetFieldsDict
Part: initFieldAlpha
 Modifying field alpha.water of type volScalarField
 Putting "0" into field alpha.water at t = "0" if condition "true" is true
 Keeping patches unaltered
 Setting 104904 of 104904 cells
 Writing to "alpha.water"
Part: initFieldU
 Modifying field U of type volVectorField
 Putting "vector(0.0,0.0,0.0)" into field U at t = "0" if condition "true" is true
 Writing to "U"
Part: pressureAir
 Modifying field p_rgh of type volScalarField
 Putting "0" into field p_rgh at t = "0" if condition "true" is true
 Writing to "p_rgh"
Part: alphaIC
 Putting "1" into field alpha.water at t = "0" if condition "pos().y<0.0006+0.00468023*pow(459.772*pos().z-19944.1*pow(pos().z,8/3)+177465*pow(pos().z,13/3),1/3)" is true
#0  Foam::error::printStack(Foam::Ostream&) at ??:?
#1  Foam::sigFpe::sigHandler(int) at ??:?
#2  ? in "/lib/x86_64-linux-gnu/libc.so.6"
#3  ? in "/lib/x86_64-linux-gnu/libm.so.6"
#4  pow in "/lib/x86_64-linux-gnu/libm.so.6"
#5  Foam::pow(Foam::Field<double>&, Foam::UList<double> const&, Foam::UList<double> const&) at ??:?
#6  Foam::tmp<Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> > Foam::pow<Foam::fvPatchField, Foam::volMesh>(Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> const&, Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> const&) at ??:?
#7  parserField::FieldValueExpressionParser::parse() at ??:?
#8  Foam::FieldValueExpressionDriver::parseInternal(int) at ??:?
#9  Foam::CommonValueExpressionDriver::parse(Foam::exprString const&, Foam::word const&) at ??:?
#10  ? in "/home/josh/OpenFOAM/josh-6/platforms/linux64GccDPInt32Opt/bin/funkySetFields"
#11  ? in "/home/josh/OpenFOAM/josh-6/platforms/linux64GccDPInt32Opt/bin/funkySetFields"
#12  __libc_start_main in "/lib/x86_64-linux-gnu/libc.so.6"
#13  ? in "/home/josh/OpenFOAM/josh-6/platforms/linux64GccDPInt32Opt/bin/funkySetFields"
Floating point exception (core dumped)
Do you have any idea what the issue is? Tough for me to see. The odd thing is, funkySetFields works on my computer for other cases, so I copied a working case into the new directory and ran it: it runs fine. Then, I copy the geometry files and blockMesh etc. from the case I want to run, and I get the above errors. It's odd because when I change to setFields (rather than funkySetFields) the case runs. I've tried self-diagnosing this issue, but I have no clue what this error implies. Help is greatly appreciated.
EDIT: FIXED IT. I THINK the error was a domain issue with the "pos().y<0.0006+0.00468023*pow(459.772*pos().z-19944.1*pow(pos().z,8/3)+177465*pow(pos().z,13/3),1/3)" condition (fractional exponents were ill-defined outside a domain).
Thanks though!
joshmccraney is offline   Reply With Quote
[swak4Foam] groovyBC and funkySetFields married and got a kid named swak4Foam gschaider OpenFOAM Community Contributions 169 August 10, 2023 09:01
initialising a thermal boundary layer at interface using funkySetFields saj216 OpenFOAM 7 February 25, 2023 11:05
[swak4Foam] how to use funkySetFields function in muliregion case bryant_k OpenFOAM Community Contributions 15 October 15, 2021 02:50
[swak4Foam] funkySetFields and funkySetBoundaryFields zxj160 OpenFOAM Community Contributions 19 February 14, 2018 19:07
[swak4Foam] funkySetFields: problem with processor boundary nmikhailov OpenFOAM Community Contributions 4 May 26, 2015 09:48
