#1 | |
Maciej Marczak
Rep Power: 6 ![]() |
Hi All
I've problem runing airfoil simulation. After typing simpleFoam command, OpenFoam gives back information about my velocity boundary conditions, and as I understand it tells me that there is no such boundary conditios as "freestreamVelocity". It is a bug or something? In the past month I've used this condition quite often learing from airFoil2d tutorial and now freestremVelocity doesnt work even there. Here is my terminal output: Quote:
Rep Power: 9 ![]() |
I think there is no "freestreamVelocity" in OpenFOAM 4. It was only added with v6.
Is it possible that you used OpenFOAM 4 by accident? At the top it says "Build: 4.0" but the case is located in your OpenFOAM 7 run directory. That would explain why it worked before. |
Maciej Marczak
Thank You so much
I don't know how the hell OpenFoam has switched to older version and I never had situation like that so I didnt even look at the OP verios information. Thanks one time I think the topic can be deleted ![]() |
Display Modes | |
RP_Set_Integer does not work in parallel | 86lolo | Fluent UDF and Scheme Programming | 2 | July 3, 2014 11:37 |
Does CX_Interpret_String work in parallel? | 86lolo | Fluent UDF and Scheme Programming | 2 | June 30, 2014 04:36 |
Companies that lease software & hardware for cloud-based work? | Catthan | ANSYS | 0 | June 18, 2014 10:53 |
Why do the Plant library cases don't work? | Alumna | Phoenics | 6 | June 22, 2004 12:08 |
why my In-Form doesn't work? | green | Phoenics | 2 | May 27, 2004 21:03 |
