Problems with SnappyHexMesh
Old   October 13, 2020, 18:57
Default Problems with SnappyHexMesh
Joaquin Moreno
joaquinmorenou is on a distinguished road
Hi , I'm meshing a cylinder in a flume that have a sandbox right below the cylinder and my problem is that when I use snappy some areas of the blockMesh mesh dissapear. In particular the 1st and the 2nd block. Right below i attached the blockMesh and SnappyHexMeshFile.
Hope you can help me
The cylinder stl : https://drive.google.com/file/d/1xei...ew?usp=sharing
FoamFile
    version     2.0;
    format     ascii;
    class     dictionary;
    object     blockMeshDict;
convertToMeters     1.0;
vertices
    (0 0 0.08) //0
    (0.8 0 0.08) //1
    (0.8 0.6 0.08) //2
    (0 0.6 0.08) //3
    (0 0 0.16) //4
    (0.8 0 0.16) //5
    (0.8 0.6 0.16) //6
    (0 0.6 0.16) //7
    (0.32 0.22 0) //8
    (0.48 0.22 0) //9
    (0.48 0.38 0) //10
    (0.32 0.38 0) //11
    (0.32 0.22 0.08) //12
    (0.48 0.22 0.08) //13
    (0.48 0.38 0.08) //14
    (0.32 0.38 0.08) //15
    (0 0.22 0.08) //16
    (0.8 0.22 0.08) //17
    (0 0.38 0.08) // 18
    (0.8 0.38 0.08) // 19
    (0.32 0.22 0.16) // 20
    (0.48 0.22 0.16) // 21
    (0.48 0.38 0.16) // 22
    (0.32 0.38 0.16) // 23
    (0 0.22 0.16) // 24
    (0.8 0.22 0.16) // 25
    (0.8 0.38 0.16) // 26
    (0 0.38 0.16) // 27
blocks
    hex (0 1 17 16 4 5 25 24)  (160 44  16) simpleGrading (1 1 1)
    hex (18 19 2 3 27 26 6 7) (160 44 16) simpleGrading (1 1 1)
    hex (16 12 15 18 24 20 23 27) (64 32 16) simpleGrading (1 1 1)
    hex (12 13 14 15 20 21 22 23) (32 32 16) simpleGrading (1 1 1)
    hex (13 17 19 14 21 25 26 22) (64 32 16) simpleGrading (1 1 1)
    hex (8 9 10 11 12 13 14 15) (32 32 16) simpleGrading (1 1 1)
edges
patches
    patch inlet
        (0 4 24 16)
        (16 24 27 18)
    (18 27 7 3)
    patch outlet
        (1 17 25 5)
    (17 19 26 25)
    (19 2 6 26)
    symmetryPlane surface
        (4 5 25 24)
    (27 26 6 7)
    (24 20 23 27)
    (20 21 22 23)
    (21 25 26 22)
    wall bottom
        (0 1 17 16)
        (18 19 2 3)
        (16 12 15 18)
    (13 17 19 14)
    (8 9 10 11)
        (0 1 5 4)
    (8 9 13 12)
    (11 8 12 15)
    (9 10 14 13)
        (3 7 6 2)
    (11 15 14 10)
mergPatchPairs
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
    object      snappyHexMeshDict;
// Which of the steps to run
castellatedMesh true;
snap            false;
addLayers       false; //pour ajouter des couches près des parois
// Geometry. Definition of all surfaces. All surfaces are of class
// searchableSurface.
// Surfaces are used
// - to specify refinement for any mesh cell intersecting it
// - to specify refinement for any mesh cell inside/outside/near
// - to 'snap' the mesh boundary to the surface
geometry
    Cylinder.stl
        type triSurfaceMesh;
        name cylinder;
        surface1
        type searchableBox;
        min (-1 -1    -0.1 );
        max (1   1     0.2);
castellatedMeshControls
    maxLocalCells 1000000;
    maxGlobalCells 4000000;
    minRefinementCells 0;
    maxLoadUnbalance 0.10;
    nCellsBetweenLevels 3;
    features
    refinementSurfaces
        cylinder
            level (1 1);
    resolveFeatureAngle 30;
    refinementRegions
    locationInMesh (0.300001 0.24 0.12);
    allowFreeStandingZoneFaces true;
snapControls
    nSmoothPatch 3;
    tolerance 2.0;
    nSolveIter 30;
    nRelaxIter 5;
addLayersControls
   relativeSizes false;
    layers
        "(cylinder).*"
            nSurfaceLayers 20;// nb de couches à ajouter prés des parois
    expansionRatio 1.19;
    finalLayerThickness 0.00002;
    minThickness 0.00000001;
    nGrow 0;
    featureAngle 60;
    nRelaxIter 5;
    nSmoothSurfaceNormals 1;
    nSmoothNormals 3;
    nSmoothThickness 10;
    maxFaceThicknessRatio 0.5;
    maxThicknessToMedialRatio 0.3;
    minMedianAxisAngle 90;
    nBufferCellsNoExtrude 0;
    nLayerIter 50;
meshQualityControls
    maxNonOrtho 65;
    maxBoundarySkewness 20;
    maxInternalSkewness 4;
    maxConcave 80;
    minVol 1e-13;
    minTetQuality 1e-30;
    minArea -1;
    minTwist 0.05;
    minDeterminant 0.001;
    minFaceWeight 0.05;
    minVolRatio 0.01;
    minTriangleTwist -1;
    nSmoothScale 4;
    errorReduction 0.75;
debug 0;
mergeTolerance 1e-6;
joaquinmorenou is offline   Reply With Quote
Old   October 16, 2020, 02:29
Thomas Sprich
Swift is on a distinguished road
Hi Joaquinmorenou,
Your mistake is in your blockMesh file. You need to build up the blockMesh shape using shared vertices to tell blockMesh that it is one shape. If you decide to do this, I estimate that you need 36 vertices and 10 blocks definitions.
The easier way of solving your problem is to make an stl shape of your geometry and put that into a bigger blockmesh cube with one block and run snappy.
Thomas
p.s. next time show images of the problem or upload a minimal case that the community can just run. This will help you get answers quicker. I had to make a case to test for you.
Swift is offline   Reply With Quote
[snappyHexMesh] Problems with sharp angles in snappyhexmesh Mathia1510 OpenFOAM Meshing & Mesh Conversion 0 March 1, 2020 08:30
[snappyHexMesh] Problems with coarse/unsnapped cells in snappyHexMesh scareneb OpenFOAM Meshing & Mesh Conversion 2 August 13, 2014 07:13
[snappyHexMesh] snappyHexMesh problems 1.5->1.6 grtabor OpenFOAM Meshing & Mesh Conversion 5 May 18, 2012 03:00
[snappyHexMesh] SnappyhexMesh and Symmetryplane bastil OpenFOAM Meshing & Mesh Conversion 10 October 7, 2008 17:07
[snappyHexMesh] SnappyHexMesh not generate mesh first time mavimo OpenFOAM Meshing & Mesh Conversion 4 August 26, 2008 07:08
