How to enter constraints for dynamic mesh
Old   October 26, 2020, 09:59
Default How to enter constraints for dynamic mesh
Spacehorse is on a distinguished road
I would like to limit my constrain my geometry to 1 degree of rotational freedom, and no linear degrees of freedom.
I am trying to use the dynamic motion solver and believe I should use an axis constraint and a point constraint, this will achieve my aim of having 1 deg of freedom in rotation.
I haven't used vectors in a while and my problem comes with entering the axis as a vector.
Axis of rotation for the geometry is at point (-0.6364, 0, 0) and the axis is parallel to the z axis.
Below is how the axis needs to be defined:
NameofAxisConstraint
sixDoFRigidBodyMotionConstraint axis;
axis (1 0 0.25);
Please can some one help?
Spacehorse is offline   Reply With Quote
sliding mesh problem in CFX Saima CFX 46 September 11, 2021 07:38
foam-extend-4.1 release hjasak OpenFOAM Announcements from Other Sources 19 July 16, 2021 05:02
decomposePar problem: Cell 0contains face labels out of range vaina74 OpenFOAM Pre-Processing 37 July 20, 2020 05:38
Moving mesh Niklas Wikstrom (Wikstrom) OpenFOAM Running, Solving & CFD 122 June 15, 2014 06:20
[snappyHexMesh] snappyHexMesh won't work - zeros everywhere! sc298 OpenFOAM Meshing & Mesh Conversion 2 March 27, 2011 21:11
